Presonus 24.4.2 with PT 10
Question?? Been thinkin about going to the presonus 24.4.2 console into protools 10. Am i able to record 24 tracks at the same time via firewire without any pci or extra interfaces???? I was told yes. If so, that rocks!!
Re: Presonus 24.4.2 with PT 10
From what I understand, non HD Pro Tools can record 32 tracks at once ...
With the 24.4.2 you can do the 24 inputs and then probably about 5-7 or so more channels but you'll need an external preamp for 4 of them ... The talkback mic has a Class A preamp that can be routed through Universal Control as well as the Aux A and B inputs ... I have the 16.4.2 and I use an external mixer when I run out of channels (for say 4 toms) ... I bring them back into the Aux A return (panned correctly on the ext mixer) and record them on a stereo track, when live, also route them to their own sub ... I want the 24.4.2 ... I bought the 16.4.2 when it came out ... bout a year later the 24 ch version showed up ...
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA "It's not the gear ... it's the ear" |
OK.. so on your 16... can you record 16 tracks at the same time via JUST firewire??
And yes PT 10 does record 32 at the same time but it is hardware/interface dependent.
My first studio pass into Pro Tools is usually 15 to 16 channels (44.1k 32bit float): 1-11: Drums 12: ProTools Click 13: Scr Bass 14: Scr Gtr1 15: Scr Gtr2 16: Scr Vox Using Furman HR6 monitoring: Aux 1: Vox Aux 2: Bass Aux 3: Gtr Aux 4: Click L&R 5: Stereo drums Presonus' Capture is only 24bit
Very Cool, Thank you for the info my friend
Hi guys, I seeking infos on presonus gear running ProTools 9.0.6. I've build a rig with a Firestudio and a Firestudio Tube chained and I can't get audio from two of the preamps, the very two "tube super channels" so called. I can't understand what happens. I can set up a session with 36 inputs thru the aggregate Audio unit but the only two I can't have are the tube pres. Any idea?
MacBook Pro 15", dual core 2 duo, 2,5 GHz 2Go 667 DDR2 SDRAM, OSX 10.6.8 PRESONUS FIRESTUDIO, FIRESTUDIO TUBE, LaCie 500Go 7200rpm. |
Anyone try PT9 with a Presonus 26/26 yet ? | Ru_C | Pro Tools 9 | 7 | 11-30-2010 09:43 PM |
New Presonus DAW? | lwilliam | General Discussion | 15 | 08-27-2009 11:25 AM |
Presonus FS8 | The Fez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-21-2007 10:51 AM |
ART vs PRESONUS | thejewdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-18-2005 08:08 AM |
Anyone Using the Presonus M80? | sugarfuzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 01-11-2002 07:13 AM |
