Old 07-12-2013, 05:45 AM
jacko's Avatar
jacko jacko is offline
Default Import Session Data bug - send assignments: doesn't clear unassigned sends!
I am experiencing unusual behaviour of importing send assignments:
There is Session_A that has AudioTrack1
There is Session_B that has AudioTrack1
I open Session_B and on my AudioTrack1 I manually assign sends A and B to respectively Bus1 and Bus2. I save and I close Session_B.
I open Session_A and I manually assign sends C,D,E to buses: 1,2,3.
Sends A and B remain unassigned.
Then I go to "Import Session Data" and I import data from Session_B. I select "Track Data to Import: ALL". After the import my AudioTrack1 should look exactly like this:
Send A: Bus1
Send B: Bus2
Send C: unassigned
Send D: unassigned
Send E: unassigned
When tested in OSX 10.6.8 and Pro Tools 10.3.2 it is exactly as above. That is how it worked since I started using Pro Tools HD back in 2006.
When tested in OSX 10.8.3 and Pro Tools 10.3.6 it looks like this:
Send A: Bus1
Send B: Bus2
Send C: Bus1
Send D: Bus2
Send E: Bus3
As you can see - the sends C, D, E remain assigned where they should become unassigned, because they were unassigned in the source Session_B.
Does anyone know how I can overcome this problem? This is a serious bug that my friend just reproduced on his system too.
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
Old 07-12-2013, 06:28 AM
Stig Eliassen's Avatar
Default Re: Import Session Data bug - send assignments: doesn't clear unassigned sends!
I tested this on my mobile rig, and I got a different result:
Send A: Bus1
Send B: Bus2
Send C: Bus1
Send D: Bus2
Send E: Bus3
Old 07-12-2013, 06:41 AM
Drew Mazurek's Avatar
I've seen this as well and logged a bug report previously.
www.drewmazurek.com
Old 07-12-2013, 08:34 AM
jacko's Avatar
Send A: Bus1
Send B: Bus2
Send C: Bus1
Send D: Bus2
Send E: Bus3
Yes, sorry - my mistake! I corrected my initial post, of course Pro Tools doesn't change bus numbers as I mistakenly posted.
Anyway, if you test it on your other rigs you'll see the difference.
Previously it was like "remove all and import" and now it is "import send assignment differences".
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Old 07-12-2013, 09:16 AM
I understand. Thanks.
Import Session Data with out Audio import disinfor Pro Tools M-Powered (Mac) 7 11-14-2010 11:44 AM
import session data without audio data rgalpin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-06-2010 01:49 PM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
import session data yields sends at 0dB Mark Dann Pro Tools TDM Systems (Mac) 0 01-22-2007 07:37 AM
