Old 11-26-2014, 05:45 AM
VRW VRW is offline
Default 11.2.2 hangs on changing buffer size
Just for the record, here on my system PT11.2.2 hangs on changing the buffer size within a session.
Happening in both directions. Cursor starts spinning and doesn´t come back anymore.
Have to shut down PT completely. When I open PT+the session again however the buffer has changed
to the required size and I can go on working like there has nothing happened before, no problem further on...
until the next time changing the buffer. Then the same procedure is required to get Pro Tools to work again.
Actually did not happen with 11.2.1. here at least.
Cheers.
Mac Mini i7Quad, 16GB Ram, MBP Mid 2012 2,5GHz i5, 16GB Ram, MacOS 10.10.1 Yosemite, Apogee Quartet+Duet 2
Genelec Active, Yamaha NS10, Pro Tools 11.2.2, Logic 10.0.7, Waves, MCDSP, Duende Native, HOFA, IK Multimedia, NI etc.
Old 11-26-2014, 06:17 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: 11.2.2 hangs on changing buffer size
Were you running 11.2.1 on Yosemite too?
Does the error happen with 11.2.2 on Mavericks?
Will
System Details
Old 11-26-2014, 06:27 AM
VRW VRW is offline
Yes, 11.2.1 on (latest update of) Yosemite as well as 11.2.2.
No other problems so far except the buffer change.
Cheers.
Old 11-26-2014, 05:54 PM
zion zion is offline
Originally Posted by VRW View Post
Just for the records, here on my system PT11.2.2 hangs on changing the buffer size within a session.
Cheers.
Working fine here on pro Tools 11.2.2 on Yosemite and Mavericks.
Old 12-15-2014, 05:46 PM
A Chapman A Chapman is offline
I'm getting this problem in 11.2.1 under Yosemite - haven't updated yet, but 11.2.1 was fine under Mavericks and Mountain Lion.
However, I find that it does become responsive again... albeit after about 5 minutes have passed.
On this machine (i7 Macbook Pro 2.2ghz 17") I often get the problem where I get a playback error, and afterwards playback is garbled. The usual fix is to change the buffer size. Obviously that's not an option any more
10.1.2 Crash when changing Buffer Size Erik318 Pro Tools 10 3 11-14-2012 06:49 AM
No audio when changing buffer size in Pro Tools 9 asaffulks Windows 9 01-16-2011 12:48 AM
Changing Buffer Size GarthVader Pro Tools 9 2 12-02-2010 12:52 PM
HELP: Changing buffer size in CoreAudio Manger? (SEE PIC) tokolosh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-23-2009 09:25 AM
Mbox-changing buffer size outside protools MOR01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-28-2006 12:50 PM
