Old 05-15-2012, 05:46 AM
Asar Asar is offline
Default Re: Pro Tools 10 HD Native Input Monitoring Glitch
thanks for the help guys. going to try out your solutions today and get back to you.
Old 05-15-2012, 08:20 PM
stationwest615 stationwest615 is offline
Soooooo, can someone tell me this...
is the problem with the Native Card or is it the new software? If it is the software, i will probably regress back to PT9 and wait till they fix the issue.
thoughts...
Old 05-15-2012, 09:24 PM
Originally Posted by Labroue View Post
I have the same problem with the Digi003, and PT10 CPTK (+ low latency input monitoring mode).
In order to work in good conditions, I found a solution. I place in the virtual console a first input channel (this is very important that it be first); I always switches the input monitoring (light green) on this first empty track.
I do not use this first track, it only allows the system to work.
Avid Please, fix this bug.
Thank you; best regards.
thanks for the tip. the empty track trick works. you can even switch the input off of your mic,enable the green input button, and just leave the track muted. seems like this is a huge software glitch. avid will get around to it soon enough i hope. thanks again, you made my sessions run smoother!
Old 05-17-2012, 04:38 PM
pellefri pellefri is offline
There's a bug running native when using Low Latency Mode, turning off monitoring when recording and not wanting audio pass through.
Audio are still monitored so when monitoring from the mixer, you get oduble signals with latency on the one from PT....
Best,
Pelle
Old 05-23-2012, 10:53 AM
Bug still exist in 10.2.0
  #16
Old 07-13-2014, 06:44 AM
polar b polar b is offline
its 2014
im using pro tools 10 hd the first version about 3 years, noe i have a problem in the input monitoring...
its not functioning in low latency monitoring...
does anyone solve this bug sofar?
i cant record this way! please help...
thanks!
George.
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
Input monitoring IN HDX/Native or Complete Production Toolkit txshonk Pro Tools 10 18 04-30-2012 06:32 PM
Input only monitoring in PT9 Native koo_koo_bonkers Post - Surround - Video 6 04-04-2011 08:02 PM
Input Monitoring with Pro Tools 9 fenders Pro Tools 9 4 01-05-2011 05:43 PM
New to pro tools, I have an input/ monitoring question mchristofi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-14-2008 05:32 PM
