Upgrade to PT10 or Memory upgrade
Need an opinion:
I'm running Mountain Lion with PT 9. Should I go for a memory upgrade or to PT10? My budget doesn't allow for both at this time. I presently have 6gigs of RAM
Motu 8pre PT11 MacPro 2 X 2.8 GHz Quad Intel Xeon 6Gig memory 1 X 320gig HD 2 X 80gig HD |
Two issues
Memory will be cheaper in the future PT11 will be out (hopefully) sometime this year. I know I didn't help but that's ur dynamic !!
Re: Upgrade to PT10 or Memory upgrade
PT10HD or PT10 + CPTK will take advantage of more RAM via disk cache, but the standard version of PT10 will not. So if you want to buy something now, you really do need both for most situations.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Then if PT9 and 10 only can take advantage of 4gigs, why do I get CPU errors when I use low buffer settings?
9 Doesn't have the disk cache function
Your buffer setting is related to the speed at which your interface can talk to your computer Really doesn't have anything to do with your RAM Your OS will operate more smoothly if you have higher amounts of RAM (on x64 systems)
It breaks down something like this. OSX itself doesn't use much ram. We'll say 2GB. Pro Tools can use up to 4GB, but in reality usually uses at most about 2.5-3GB. So your 6GB can cover that. If you have something hosting external VI's or your VI has an external memory server, it can access more RAM. But that's dependent on the VI and host. Most people are fine with 4-6 GB, with the expecting being HD/CPTK users using disc cache. So in essence if you want to use low buffer settings with no errors you need more/faster cores/procs.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
I had no idea it was related -
On another note I did happen to lower my buffer settings with upgrading my hard drives as well - I went from 8mb cache to 32mb cache and it was tons more stable !!!!
The hard drive buffer holds data until it's ready to be read/written. If it's too small the system has to wait for space to be cleared before data can accessed/written. The playback buffer is essentially how many samples (how much time) the CPU has to process the signal. So bigger buffers allow more time to get the signal processed and output. Hence lower buffers need more/faster cores/processors.
Large playback buffer = Less CPU usage, but more latency Small playback buffer = Less Latency, but higher CPU usage If you want to be able to run smaller buffer sizes, you need to upgrade your CPU, which for a mac pro means a newer computer(There are ways to upgrade the CPU in some mac pros, but I don't think they are worth it in most cases). Quote:
Pro Tools 10HD's disk cache feature should not be confused with a 64 bit app. What it does is take unused RAM and treat it like a disk, so all of your audio is streamed directly from this RAM disk(much faster than reading it from a hard drive, so for huge sessions like a film mix you don't need to have your sessions spread across multiple drives). But the actual pro tools app for ANY version of Pro Tools 10 is still 32 bit.
Thanks to all for the explanations. Realy help to clear up a lot.
One last Newb question: When I run an instance of Addictive Drums and Xpand2, are we still talking abut CPU hit or Memory Hit?
PT10 from PT9 upgrade with free PT11 upgrade | curlydog | Pro Tools 10 | 4 | 05-10-2013 08:32 AM |
How to reinstall PT10 if PT10.3.2 upgrade failed? | Martin11 | Windows | 12 | 12-09-2012 03:16 PM |
Memory upgrade | darkglass | Pro Tools TDM Systems (Mac) | 5 | 10-05-2009 09:01 PM |
memory upgrade | Jonah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-17-2003 12:41 AM |
The best memory upgrade | MB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-16-2000 11:56 AM |
