How to go from Apple TV digital out to MTRX?
I want to extract digital audio from an Apple TV 4th Gen with a HDMI + HDMI Audio extractor box. This extracts an Optical output from the HDMI signal. This then goes to a HOSA Optical to AES/EBU converter box. And from here it goes to the Avid MTRX AES-in.
This doesn't work because the extractor doesn't have a Optical IN for clocking. The result is the audio plays but drops out every few seconds. No HDMI audio extractor I've found have an Optical IN, only OUTPUT. Is there a better way to do this? I need all my MTRX analog inputs otherwise I just use them.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
Re: How to go from Apple TV digital out to MTRX?
So you are trying to record the audio signal?
Usually the output from the Apple TV is a Dolby encoded output. Are you tying to record a simple stereo, 5.1, or Atmos?
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
Just want Apple TV playback, no recording. And just stereo...
If clocking is the only issue change you Pro Tools/MTRX setup to clock from its AES/EBU input.
Thanks, I just tried that but get a SYNC Loss alert and the audio still drops out every 5 seconds or thereabouts...
Then you likely have other problems in the conversion chain than just clocking. Can you try swapping components/cables. Can you run TOSLINK into the AES/EBU converter say from a CD player or a Mac with optical out to test that works. Is it an old Apple TV with TOSLINK out that you can go directly into the TOSLINK Adapter?
It's a 4th Gen Apple TV so have to use an HDMI + HDMI Audio extractor box. This has a Optical out only. I did swap cables. I generally find that whatever I hook up using the AES inputs on the MTRX, I need both IN and OUT connected. For example, I have a HAKEN Continuum controller hooked up via AES, but I get dropouts or it won't work at all unless it's connected to both AES In and Out.
Any chance you have a Dante card on your MTRX? I use these adapters to get as much audio input as I need....
https://www.amazon.com/Audinate-Dant...C4Y?th=1&psc=1 I know it doesn’t directly solve your problem, but thought I would mention that Incase the sync issue doesn’t work out.
Thanks for that, looks interesting. I'd get a Dante card if it's solve this clocking issue, since I'd to stay digital if possible. But you're saying with this I could go analog into the Dante card. That might be the way to go...
Not sure going Dante to just get analog would make sense.
Do you have something like an RME ADI-192 DD you can borrow? That gets you SRC (pretty sure it regens off the input clock at the same sample rate) tied to a clock signal. Super handy boxes, but overkill in general for this... but if you can borrow one. Are other MTRX as touchy for locking to AES/EBU? I'm more guessing your Apple TV may be running a little loose. But if it happens with other stuff... What computer do you have? Does it have optical in? (I'm guessing from your info you mean a late 2013 trashcan, so no). Maybe consider buying a USB or thunderbolt interface with optical in and switch to Pro Tools Standard while importing that S/PDIF input. |
HD I/O with MTRX | Artis | Pro Tools | MTRX & MTRX Studio | 10 | 07-04-2019 10:01 AM |
MTRX and S6 | quadraphonics | Avid S4/S6 | 18 | 08-21-2018 06:12 PM |
MTRX Box | JSR | Avid S4/S6 | 4 | 11-01-2017 12:46 PM |
MTRX | antonis | Post - Surround - Video | 2 | 10-26-2016 12:31 AM |
Anyone been able to get 2 Apple digital monitors working? | EthanMorse | Pro Tools TDM Systems (Mac) | 0 | 11-06-2001 10:02 AM |
