Old 04-28-2013, 05:30 PM
wonderlife wonderlife is offline
Default Pro Tools LE 5.1.1. where to download update file?
Hi there,
Coming from a long time user of the Digi001 (Mac OS 9) system. I was wanting to get the update file for Pro Tools LE 5.1.1. Based from the archive.digidesign.com website, it is a free download for PT LE 5.1 users, unfortunately though the link that is provided is broken and does not allow me to download the free update. I was wanting to know, would someone have a link to the update file?
Thanks for checking my thread, hope to hear from you.
Old 04-28-2013, 07:03 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Pro Tools LE 5.1.1. where to download update file?
You should search the DUC b/c I have seen people posting the active link b/F - every once in a blue moon - someone asks for it and say its dead - someone then. Finds the active one
Do a few good searches and you might find the last post asking doe those links
Daniel
YYR123's Avatar
I have an extra 001 how much you wanna give me for it ???
Daniel
Old 04-28-2013, 10:05 PM
Hi yyr123,
thanks for your reply, unfortunately that seems to be the problem it only comes up once in blue moon... ps thanks for the 001 offer, but I'm set with equipment at this moment
If someone may have an active download link, it would be great to hear from you.
Old 04-29-2013, 05:31 PM
Hi everyone, a thought that came to mind. I still have my disc for PT LE 6.4 with the registration card, if I send that through would Avid be able to provide me with the PT LE 5.1.1 update?
Old 04-30-2013, 07:54 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
I didn't try downloading it, but the page for it is still up:
http://archive.digidesign.com/download/511/
EDIT: looks like you need to enter your serial number to be able to download.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 04-30-2013, 04:13 PM
Hi John,
Yes that's the page, the very one that leads to broken link. After filling in the form, with serial number, name, read the licence agreement, etc, then I click on "I Accept - Download" and get taken to this page:
The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
Datasource digi_base could not be found.
Resources:
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debug Output Settings, and select the Robust Exception Information option.
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/5.0 (Macintosh; Intel Mac OS X 10_8_3) AppleWebKit/536.29.13 (KHTML, like Gecko) Version/6.0.4 Safari/536.29.13
Remote Address 198.37.38.254
Referrer http://archive.digidesign.com/downlo...pt511_form.cfm
Date/Time 30-Apr-13 11:04 PM
I've tried different browsers and the result is the same. Is there an alternative way around this?
Old 05-01-2013, 05:54 AM
If someone may have a copy of the update and are able to upload, I would really appreciate hearing from you.
Old 05-02-2013, 05:39 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
You can download the updates from Pro Tools LE 5.1 here:
Pro Tools LE 5.1.1 Updates
Bruce Paine
System Details
Old 05-07-2013, 05:13 AM
Hi Bruce,
Thanks heaps for the link! Much appreciated
Pro Tools 8.0.5 Update Now Available for Download Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-10-2011 10:09 AM
Pro Tools 8.0.5 Update Now Available for Download Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-10-2011 10:09 AM
Pro Tools 8.0.5 Update Now Available for Download Avid Pro Tools M-Powered (Mac) 0 03-10-2011 10:09 AM
Pro Tools 8.0.5 Update Now Available for Download Avid Pro Tools M-Powered (Win) 0 03-10-2011 10:09 AM
Pro Tools LE 7.3.1cs4 update - can't get the download Torchlight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-15-2007 02:10 PM
