Old 02-28-2021, 09:33 AM
depinfinity depinfinity is offline
Default Blank Sign In Window Pro Tools
I've been having an issue where I can't sign in to my Avid account while in the Pro Tools program. I click "Sign In," and a blank window pops up. This problem used to come and go, and sometimes would be able to sign in. Anyone know how to solve this?
Old 02-28-2021, 10:33 AM
Default Re: Blank Sign In Window Pro Tools
Try a different browser
Old 02-28-2021, 10:55 AM
This is within the Pro Tools program itself.
Old 03-02-2021, 10:31 AM
junkgear's Avatar
junkgear junkgear is online now
Is this working for you now?
There were others with this issue too, but it seems to be working now.
Will
System Details
Old 03-02-2021, 02:27 PM
No. Still not working.
Old 03-02-2021, 04:34 PM
junkgear's Avatar
Are you running any virus software or firewall that would block the connection?
You can also check in Windows Services and make sure both the Avid Hub and Transport services are running.
Will
System Details
Old 03-02-2021, 10:24 PM
I'm running Webroot SecureAnywhere and Windows Firewall, but I've made sure to allow Pro Tools and associated services through both. Both Avid Hub and Transport services are running in Windows Services.
Old 08-17-2021, 11:36 AM
Doug Logan Doug Logan is offline
I'm having this problem too. Has anyone figured out what's going on?
Just downloaded latest Pro Tools First (2021.7) on a new Windows 10 laptop that has never had Pro Tools before. I have Bitdefender anti-virus but have disabled the firewall.
I signed in the iLok app and assigned a license to this computer, all good so far.
Now starting Pro Tools, the startup progress dialog appears. Soon a blank dialog pops up and main progress dialog says "Signing in to your Avid account" on the bottom and waits... forever (see first attachment). Finally I dismiss the blank dialog with the x in the corner (the x is the only thing showing on the dialog). Pro Tools then finishes initiating and starts the session dashboard. I cannot open or create any sessions from this dialog: the create button is inactive I guess. In the upper right it says "Sign In", so I click that and get the same blank dialog (see second attachment).
I can't find any way to open an existing local session either, so the app is bricked.
Old 08-17-2021, 06:11 PM
sw rec sw rec is offline
Cloud-based, or physical I-lok?
Old 08-18-2021, 07:04 AM
software/cloud
Blank "Sign in Window" PT First Odee Pro Tools | Intro Discussion 15 01-26-2018 08:35 AM
Eleven Rack blank window with Pro Tools 10 jamieguitar Eleven Rack 9 07-21-2013 12:02 PM
Edit window blank jeff5x0 Eleven Rack 2 06-27-2013 10:41 AM
Blank sections and out of sync amps view in Eleven Rack window in Pro Tools LE 8 dbvoyager Eleven Rack 6 12-02-2012 12:13 AM
Blank "Welcome To Pro Tools LE" Window voicemanb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-11-2009 02:09 PM
