HD replacement for MacBook Pro (internal)
Hi all,
Running PT 9 on my MB Pro (3,1 / 2.4 GHz / 4 gigs RAM). The internal drive is 150 Gigs, 5400 RPM. I'd like to install a larger drive. Recommendation please? Concerns: ---"Quiet"-ness. ---Reliability ---Of course, price. If I went to a 7200 rpm drive, will I experience: ---Better performance? ---Noticeably worse battery life? Thanks ! |
Re: HD replacement for MacBook Pro (internal)
I've been researching this and the seagate momentus XT seems to be the way to go in a price vs performance issues.
not sure about the battery life but it certainly does seem to provide better performance, for sure.
Jay-J System MacPro 12 Core • 24 G Ram • 10.12.6 PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified 4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage MAXPower eSATA 6G Card • Wiebetech RTX100H-Q Kensington Trackball Works/Orbit Optical Bluetooth off/Airport on and off. |
How much space do you need? I'm planning on putting a 125GB SSD in my MBPro and take out my 500GB/7200RPM and put in an external case. With an SSD, the battery running time should increase dramatically, as well as boot-up speeds, not to mention program loading times!!
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
My 150 Gig internal drive is almost full. Even after I've done a lot of "housekeeping", and pulled unnecessary things off the drive. So, I was looking at at least 250, but more likely 500.
Not all SSDs are equal. Do your research.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Re: getz76, the specs for OWC products are highly rated.
Actually, it's pretty "meh" for the price. The OWC uses a Sandforce controller, the same controller in the OCZ Vertex 2 line of drives. They are similar in performance, with the OCZ Vertex 2 besting it by marginal amounts.
The OWC MX240 runs about $500. The Vertex 2 240gb runs $390. While the OWC has a better warranty (5 years vs. 3 years), that is too much of a price difference for me.
I replaced the internal HD's on all three of my MBP's day one of their life. I can't therefore comment on battery life - but for DAW that isn't important to me. I have done 36 tracks with full I/O on the internal with not a problem.
-D |
I put in the Seagate Momentus 7200.4 ST9500420AS 500GB 7200 RPM 2.5" SATA 3.0Gb/s Internal Notebook Hard Drive -Bare Drive from NewEgg over a year ago in my 17" MBP, no issue with battery life and having 500Gb really helped out
i7 950, 12Gb, 3 Tb, Win7-64 and 32bit PTHD 12.7 HDCore 1 & w/002r Macbook Pro 4Gb, 500G, OSX 10.6.2 iMac 3.06ghz, 16Gb, 2Tb, OSX 10.6.2 Minimoog Voyager, Liberation, Taurus, Phatty Korgs, Nords and more Arp 2600s & Ody |
I have a momentus XT 500 GB. I am not so happy with it. The Seagate guys cannot get a good firmware update for the drive. The Momentus XT forum shows many with problems especially on Macbook (Pro)
http://forums.seagate.com/ I read that a 750 GB 7200rpm Travelstar gives almost the same performance as a Momentus XT. For now I would suggest you to take such a drive. Even though my drive is now more or less stable, I cannot use Intego Virusbarrier. It seems that Intego 'sees' the activity on the SSD portion of the Momentus disc as 'viruslike'. I cannot add that part to the trusted files. I am now using Firmware version SD25 on the momentus xt but under SD23 and mainly under SD24 I had major problems losing the structure of my disc. For now stay away from the momentus XT. Try it when it gets better. Especially Older macbook models seem to have many problems. I have MacBook Pro 5.5 and I seem to have relatively minor issues. |
2 internal Hard drives in a Macbook..... | JazzyJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-15-2011 06:20 PM |
PT9 with internal speaker/mic on MacBook pro | SixChurchStreet | Pro Tools 9 | 4 | 11-08-2010 07:19 PM |
Is there a replacement Internal Talkbak Mic | Amr Mahmoud | ICON & C|24 | 1 | 11-07-2008 04:37 AM |
Macbook Pro internal hard drives | soulgod60 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-07-2006 02:07 PM |
PT LE 7.1, macbook pro, no sound internal speakers | caz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-19-2006 09:22 PM |
