Old 12-21-2010, 06:12 AM
Zownd Zownd is offline
Default Anyone switch from 8core to 6core
I have an older 2008 model 8-core 2.8
Will going to six cores in the newer mac running at 3.33 get the same amount of plugins? (or more?)
the reason for going 6core 3.33 is that all other operation will be faster, even faster then a 12 core.
thanks for reading and maybe your ideas.
cheers,
Mark
Old 12-21-2010, 08:51 AM
writeroxie writeroxie is offline
Default Re: Anyone switch from 8core to 6core
Hi Mark,
This may not help at all, but after installing PT 9 I did the Dverb test on my Mac Pro - which power-wise seems to sit between the two machines you're comparing. Here are my results:
Protools 9
Mac Pro 2x 3ghz Xeon Intel (8 cores total) w/8g RAM
Snow Leopard 10.6.4
DIGI002R
Dverb score: 272 (on 6 cores)
Dverb score: 325 (on 8 cores)
Old 12-21-2010, 10:57 AM
Park Seward's Avatar
Park Seward Park Seward is offline
With the same chip speed, using fewer cores will produce a lower result. However, using fewer cores at a higher rate may improve the results. It all depends on the speed.
I picked the current 6 core over the 8.
8 X 2.4 = 19.2
6 X 3.3 = 19.8
Your older model may produce similar results but the RAM and internal bus are faster in the 2010 model. However, I would not expect a vast improvement.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
New Mac Pro – 8core-16 gigs of RAM verse 6core-64gigs of RAM toolgirl macOS 58 01-26-2014 01:32 AM
6core/12thread i7 worth it? kocha Windows 4 05-23-2012 03:52 AM
Mac 8Core & PT8HD /10.6.3 ? PMoshay Pro Tools TDM Systems (Mac) 20 06-27-2010 11:27 PM
Mac 8core 2.8 gHz Harpertown 16-32 gig RAM vs. New 2.66 gHz Nehalem with 8-16 gig Ram abenkori 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 08-27-2009 09:44 AM
New Mac Pro 8core! koka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 01-21-2008 07:29 AM
