Old 05-02-2009, 12:03 PM
usastra usastra is offline
Default Is it possible to use a Command 8 in combination with a D-Command?
I'm planning to setup a D-command system with a Command 8 in the vocal booth but was wondering if it's possible to use them at the same time.
Old 05-03-2009, 01:23 AM
mix109 mix109 is offline
Default Re: Is it possible to use a Command 8 in combination with a D-Command?
http://www.digidesign.com/index.cfm?...&categoryid=34
Can Command|8 and HUI (or another control surface) work together?
No, Command|8 must be the only MIDI control surface enabled within Pro Tools.
Command|8 may be used with non-MIDI control surfaces (D-Control, D-Command, ProControl or Control|24) with some limitations.
When used with Control|24, Command|8 faders overlap (i.e. duplicate) the left-most eight faders currently banked on Control|24.
Old 05-03-2009, 01:44 PM
Thank you!
Any difference besides color between D Command and D Command ES? diamondschwin Pro Tools TDM Systems (Mac) 10 03-12-2012 12:15 PM
Command Keyboard Focus mode ' E ' command bug ? vudoo Pro Tools TDM Systems (Win) 2 09-10-2009 05:49 AM
command 8 and usb hub evs ProControl, Control|24, Command|8 3 10-18-2006 12:47 PM
Total Loss of Command 8 Command/Modifiers John Pisciotta ProControl, Control|24, Command|8 1 05-13-2005 10:30 AM
What's the command key for... moblues 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-05-2004 03:57 AM
