Old 04-23-2018, 05:33 PM
DualCoreX2 DualCoreX2 is offline
Default Latency with Pro Tools Ultimate vs. regular Pro tools 2018
I have had issues with latency using Pro tools 12 and I'm wondering if upgrading to Pro Tools Ultimate would help me with latency issues?
I have an Apollo Twin and an iMac 5k with 32gb of memory running High Sierra 10.13.3
Yes, I follow best practices regarding reducing latency and have followed Avid's suggestions to no avail.
-Joe
Old 04-23-2018, 08:35 PM
BScout BScout is offline
Default Re: Latency with Pro Tools Ultimate vs. regular Pro tools 2018
No. Regular or Ultimate with the same audio interface will have the same latency
Old 04-23-2018, 09:16 PM
Thank you for the quick reply.
What is the most affordable audio interface that Avid sells that would help reduce or eliminate latency?
Old 04-23-2018, 09:22 PM
Sardi Sardi is offline
Are you monitoring off the Apollo or back from PT?
If you monitor from your interface, you should be able to get indistinguishable latency. Buying an AVID interface to reduce your latency is going to require you moving into HD territory. It’s a big change and a serious investment.
Old 04-24-2018, 09:03 AM
With Apollo, you have 2 things to consider;
#1-if you wish to track using any UA plugins, you MUST monitor thru the UA mixer window.
#2- AFAIK, plugins inserted directly on Pro Tools tracks will all suffer over 1000 samples of latency(so its better procedure to insert the plugins in the UA mixer).
That's the beauty and the curse of Apollo
Old 04-25-2018, 08:17 AM
YYR123's Avatar
YYR123 YYR123 is offline
Yes to all the above,
Monitor through the Apollo Console App and you will have no "Major" latency.
Problems arise when your PT buffer is super high and monitoring through Apollo but recording Midi.....(this will cause you to loose your mind).
When recording midi always lower your PT buffer to the lowest possible setting to minimize your midi latency.
Daniel
Pro Tools 2018.1 low latency monitoring issues stakeoutstudios Pro Tools 2018 61 04-15-2020 07:15 AM
PT 2018.4 Ultimate bugs ? Glazik Pro Tools 2018 26 07-10-2018 11:56 PM
Pro Tools Ultimate 2018.4 GUI offset by tabs error Mike Ritchie Pro Tools 2018 2 04-10-2018 03:49 PM
Will Pro Tools Express Transpose notes like the regular Pro Tools? bbbbbbb40 Pro Tools Express on Windows 0 12-16-2014 05:25 PM
whats the difference between regular pro tools and pro tools 9 academic? Abel0470 Pro Tools 9 5 01-20-2011 01:09 PM
