Old 03-01-2018, 03:51 PM
Tex Tiles Tex Tiles is offline
Default Mac os 10.6.8 no midi inserts with Mbox2
Just recently my macbook pro with 10.6.8 does not see any midi inputs in the Audio / Midi system prefs. It does however work fine on my other hard drive running 10.5.8 so I know that it is a software error in the mac os and not hardware.
So it loads Mbox2 as an interface but does not detect any midi inputs on the Mbox2.
Does this mean I have to re-install my os? I have already tried trashing prefs and re-installing the Mbox2 driver.
It's driving me nuts. Everything else works fine except it doesn't recognize any midi inputs.
Repeat, not a hardware or cabling issue as it works perfect on the different hard drive and system.
Thanks for you help on this...
I am a little hesitant to re-install my OS as it might muck up other things...
Old 03-01-2018, 04:29 PM
Default Re: Mac os 10.6.8 no midi inserts with Mbox2
Is it ONLY midi that is not working? Might be tough to fix as Mbox 2 is no longer supported(so it might be the OS update that killed the midi function). There are plenty of MIDI-USB interfaces on the market. Just get one that supports the current OS(if you have an open USB port). No open USB? Maybe its time for a new interface?
Old 03-01-2018, 10:15 PM
Hi Dave, thanks for the response. No it was working fine on 10.6.8 and then the other day stopped detecting any midi inputs on the Mbox2.
I suspect the OS audio/midi is corrupted. I guess I have to re-install the os probably...
Old 03-02-2018, 09:57 PM
Well it looks like it fixed itself. After I used my ilok for protools 9 on this computer, it now works normally in garageband and logic. I guess protools loaded it up differently and now it works like normal in apple programs. go figure...
thanks
Midi inserts - PT10 for Nord Electro 3 magnoliavine Pro Tools 10 0 08-17-2014 11:25 AM
Importing MIDI from Band in a Box/No Inserts column hughbar Windows 4 11-10-2013 10:08 AM
no instrument, inserts, sends on MIDI track? michaelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-31-2009 12:59 PM
MBox2 I/O Inserts - any use for these? ChuckS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-03-2008 03:20 AM
Mbox2 Plug-ins aren't showing up in my inserts BroganSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-25-2007 09:52 AM
