Old 08-23-2018, 04:35 PM
dalonso66's Avatar
dalonso66 dalonso66 is offline
Default Can't change default format/path order in I/O
Well, I've never had this issue before but I can't change default format or path order in I/O.
Using Pro Tools Ultimate and Omni.
2018 3.2 GHz Mac Mini 6 Core, OS 11.6.8 64GB Ram
PT Ultimate 22.7.0 - EuControl 22.4 - Avid MTRX Studio - Pro Tools Dock - JBL 705p Monitors
Old 08-23-2018, 04:53 PM
BScout BScout is offline
Default Re: Can't change default format/path order in I/O
For the Omni, you have to go to the Setup>Hardware>HD Omni>Monitor tab.
Old 08-23-2018, 05:02 PM
dalonso66's Avatar
Yeah, I did and that everything is functioning just fine, but I recall that default path and format used to display, 5.1 and the 5.1 channel order in previous versions.
Old 11-20-2019, 07:08 AM
AnnaMy AnnaMy is offline
I've got the same problem. Did you manage to solve it? If so, how?
Really grateful for any tips, as it's suddenly switched to Default I/O Stereo and can't be changed to 5.1 any longer.
Many thanks,
AB
PT Ultimate 2018.7.0
HD Native Thunderbolt
IMac MacOS 10.14.1 (Mojave)
Old 11-20-2019, 11:39 AM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
I am having issues using the Monitor path when changing the output order in the Hardware Monitor tab. Was on with an Avid support tech both by phone and remote desktop trying to get the Monitor path to output correctly after setting up the desired output order which didn't happen. The case is still open and was updated a couple days ago with no solution. I am bypassing/disabling the Monitor path and just using the Omni analog outs as my surround output path. If you are experiencing something similar and have an active support plan please report it so they have more incentive to look into it. Thanks!
I will choose,
Freewill
http://jimdiazaudio.com/
Old 11-21-2019, 07:20 AM
dalonso66's Avatar
It still has not been fixed.
5.1 Monitoring works just fine nonetheless.
Edit - To be clear, I'm just doing what CygnusX (above) is doing: "... using the Omni analog outs as my surround output path."
I'll open a ticket with Avid as well.
Old 11-26-2019, 04:15 AM
Thanks! I'm waiting to hear back from Avid too.
To switch the 5.1 monitoring using the Analogue Omni outputs - which output routing are you using instead? Would you mind sharing a screenshot of your Monitor window of the HD Omni?
Many thanks,
A
Old 11-26-2019, 12:37 PM
kcfroines kcfroines is offline
I guess I'm not following what the issue is here. Just disable everything in the Hardware Monitor page and assign normal outputs instead?
I'm playing around with one of the Omni's here and it all seems fine. Can switch between seeing the "monitor" output and normal 5.1 LCRLsRsLFE without any issues
Are there any advantages to running an Omni with a "Monitor" output vs a regular 5.1 output like any other HD IO/MADI IO etc...?
Old 11-26-2019, 12:43 PM
I believe the only advantages are:
  • being able to use the volume control knob on the front for "Monitor"
  • Allowing "Monitor" to work with the fold down function
If sending to another monitor controller/volume knob, you'd probably not want either.
Old 11-27-2019, 05:04 AM
I've got the exactly same problem as dalonso66, who started this thread and I would like to see a screenshot of the workaround, as it's the easiest way to illustrate it.
I've attached a screenshot of my Outputs tab in the I/O window, as well as my Hardware Setup>Monitor window. As you can see, I can no longer select 5.1 as the Default Output, so as a result, my 5.1 output doesn't play out to my 5.1 speakers. It only plays out Stereo.
I have no idea what caused this and have been unable to find 1. many others with the similar problem 2. a solution from those who has had the same problem. I was hoping the Avid Forum would be able to help.
Any tips/workarounds would be most welcome. Cheers!
Attachment 12315
5.1 path order bug? soundgott Post - Surround - Video 3 11-20-2012 12:22 PM
Eq, compressor order in signal path matthewacacia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 03-26-2009 06:38 PM
Can you change the default channel order of an interleaved.. dj_grimmace Post - Surround - Video 4 11-12-2007 08:10 AM
Surround default path ^Tripper^ Post - Surround - Video 16 12-18-2006 10:07 AM
Hardware Setup Default file path? Mr. Rubberburner Pro Tools TDM Systems (Mac) 1 10-18-2005 03:39 PM
