Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 09-29-2018, 03:47 AM
werner44 werner44 is offline
Default Re: Firmware updater doesn't recognize Avid Pro Tools Duet
Same problem with the new 2.68 drivers again.
Only this time I tried updating from Windows and it downgraded the firmware to 2.63 instead
The new firmware update installer seems to be broken since it says I should eject the image everytime I try launching it.
Any help?
Old 02-25-2019, 12:01 PM
robertemery2203 robertemery2203 is offline
I have an issue with my PT Duet. The Pro Tools I/O Control Panel says No Avid System Found. I cannot seem to fix this. I have uninstalled and reinstalled etc to no avail. Can anyone advise?
Old 02-25-2019, 12:04 PM
Default Pro Tools I/O Control Panel
Old 02-25-2019, 01:40 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: Pro Tools I/O Control Panel
Mac? Pc? OS?
More info?
IMDB
Old 02-25-2019, 04:02 PM
Default Re: Avid Pro Tools Duet not recognized by Firmware Updater or Pro Tools I/O Control P
Fixed itself. There was a problem with Native Instruments using up the protools deamon / core audio application and blocking the updater from recognising the audio interface for some reason. I use a 2013 iMac. If anyone else has this problem I advise manually closing all audio applications in the activity monitor and maybe force quitting core audio
Duet Display for Pro Tools | Control users Righty27 Avid S1, S3, Dock and Control App 8 01-23-2019 05:03 AM
Control panel : no AVID system found with Pro Tools Quartet Reuh Pro Tools | Duet & Pro Tools | Quartet 1 01-06-2019 05:42 AM
Pro Tools | Duet NEW Firmware v2.68 from AUG2018 Cacov Pro Tools | Duet & Pro Tools | Quartet 0 09-07-2018 10:50 AM
HELP: ProTools duet firmware updater does not detect Duet mikeserman Pro Tools | Duet & Pro Tools | Quartet 1 10-18-2015 03:12 PM
Why don't I see the Pro Tools 10.0.1 updater in my avid account? nexis Pro Tools 10 23 02-02-2012 08:18 PM
