Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 06-09-2017, 09:10 PM
Kevn Blvk Kevn Blvk is offline
Default HD Native I/O does not show in playback engine
The HD Native I/O doesn't show up in the playback engine on some computers. But shows up in every other DAW on the computer. Has anyone else had this issue?
Old 06-10-2017, 09:36 AM
Default Re: HD Native I/O does not show in playback engine
Not enough info. What exact version of Pro Tools? If its 12.6 or newer, do you have the required Digilink license on your iLok?
Old 10-07-2017, 05:08 PM
porkyman porkyman is offline
yes me. havent found solution.
i7 7700 16gb win 10 pt 12.8
Old 10-07-2017, 09:12 PM
What is the OMNI connected to? HDN card? HDX? HD/Native Thunderbolt? Is Windows using the OMNI as its default playback device? If so, that could be the issue. Open Control Panel>Sound>Properties and select the on-board sound card as the Windows default playback device
Old 10-07-2017, 10:15 PM
And what exact version of Pro Tools? Pro Tools standard or HD?
DigiLink interfaces require Pro Tool HD (will not work with Pro Tools standard) andafter Pro Tools HD 12.6 alo require a DigiLink license.
In cases like this where things work on soem but not other computers it is often that those other computers have the wrong license assets on the attached iLok. Go into ILM on each computer and see what exactly is on the attached iLok. Try remobign all be the iLok with the HD (and possibly DigiLink) license on it.
Old 12-31-2017, 12:50 PM
Dan IceWood Dan IceWood is offline
as said before...
What version of PT, what OS etc
RE: HDX does not show up in playback engine. [PROBLEM SOLVED!] adrianrobison Pro Tools HDX & HD Native Systems (Mac) 5 02-17-2016 02:57 PM
No HD Native option in Playback Engine select ronstephens Pro Tools HDX & HD Native Systems (Mac) 9 07-02-2015 09:16 AM
PT Native HD10.3.2 Forgets Playback Engine ronstephens Pro Tools HDX & HD Native Systems (Mac) 2 11-08-2012 09:35 PM
PT 9.0.5 Native has problem with playback engine JoeM Pro Tools HDX & HD Native Systems (Mac) 2 12-04-2011 06:08 AM
Windows 7 64-bit PT 9.05 does not show Mbox 2 Mini as playback engine option brunorio Windows 4 09-14-2011 06:46 AM
