Old 11-16-2012, 09:16 PM
Rjones17 Rjones17 is offline
Default 8ch FireWire or USB Interface w/ PT MP9
I'm in need of buying a compatible 8ch Mic Input FireWire or USB Interface to use with Pro Tools MP 9.0.5. I've seen the following units however I can't find good online info. to confirm compatibiliy. If anyone can guide me to an online resource, I would greatly appreciate it. If you have experience, pros & cons with certain units, please let me know.
- Focusrite Saffire Pro 40 (read something about ASIO problems)
- PreSonus FireStudio Project (old model was FireStudio)
- M-Audio ProFire 2626 (read about Low Latency Monitoring problems)
(I believe it's discontinued. What's replaced it?)
- Mackie Onyx Blackbird
- Steinberg MR816 X
- Roland Octa Capture 10x10
System: MacBook Pro, OS 10.6.8, M-Audio FW410, Axiom 61, Yamaha NS-10 monitors
Old 11-24-2012, 12:58 AM
The Dougfather The Dougfather is offline
Default Re: 8ch FireWire or USB Interface w/ PT MP9
Isn't Pro Tools MP a version that forces you to use M-Audio hardware?
http://www.avid.com/us/products/protoolsmp
M-Audio appear to cutting back on their interfaces, you want my opinion, avoid them!
Pray you never get a problem because their service is horrific!
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 11-24-2012, 08:25 AM
nst7 nst7 is offline
Dougfather is correct.
If you are using MP9, you are required to use an M-Audio interface, so that narrows your possibilities.
It's only "regular" Protools that allows you to use any interface.
Old 12-04-2012, 12:36 PM
So the ProFire 2626 is my only option for an 8ch interface. Does anyone know what limitation I'll have for sample rate trying to use all 8 channels at once? The max sample rate for PT MP9 says 96k although I've seen some notes out there stating I might not get that when trying to use all 8 channels on the ProFire 2626. Is there anywhere I can confirm what it really is?
Old 12-14-2012, 08:55 PM
I have a FireWire 410 which is M-Audio compatible. Can I add something like the Saffire Pro 40 via FireWire daisy chain to the 410? I don't believe the 410 has ADAT but will this scenario give me the added channels in ProTools MP9 to record?
Old 12-14-2012, 09:06 PM
No, because it will not recognize the Sapphire, being M-Powered. Again, you need regular Protools.
Problems with PT9 and FireWire interface FT13 macOS 5 12-28-2011 10:38 PM
1 interface, 1 hard drive, only ONE firewire interface? beyoutofull1 Pro Tools M-Powered (Win) 5 11-22-2010 05:08 PM
Firewire vs USB interface Jeff E Pro Tools M-Powered (Mac) 1 08-12-2008 07:16 AM
firewire interface kav 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-01-2004 09:26 AM
96kHz FireWire Interface Tone Pro Tools TDM Systems (Mac) 16 12-19-2001 01:52 AM
