Delay compensation, SC48
Having watched Scoville's parallel compression tips webinar...I have a few simple questions on an SC48:
- If you have a plugin on a single channel, does delay comp have to be on in order for the rest of the channels to be auto-aligned at the main buss L/R?? - If you fed a single input into 2 single channels, and put inserts on one and left the other dry...would delay compensation align them if they were both coming into the L/R buss? Or are you required to manually delay the dry one? - For FX bussed plugins...how is the latency accounted for when the signal is returned to the main buss?? Thanks! |
Re: Delay compensation, SC48
1. Yes, also remember to take an unused channel and press all of the buttons (L/R, C, all groups) it was one of the things Robert said "tricks" the console to aligning things
2. If you feed them into separate groups the delay compensation will take care of it, if you feed them directly to L/R I believe you would need to align them at the channel level. 3. Not sure about the last question, but wondering why it would matter since by nature the plug in already changed the time anyway. |
Hi Terry,
I'll expand on this a bit. Quote:
Delay compensation does NOT automatically align all input channels going to mix just because a plug-in has been inserted on one channel. If channels aren't being double bussed, no additional latency is introduced, even if delay comp is on. Quote:
Sheldon |
Ah! This is very helpful Sheldon...thank you!!
Hi Sheldon,
Thanks for that info... So - I have a couple of Sansamp plug-ins that I'm using to add some distortion to drums and vocals on certain songs. The one on drums is sent from a post-fader aux and returned to a channel, so does this mean it won't be delay compensated? If I inserted it on a group instead would it then be delay compensated? I'm running 16 auxes plus 8 variable groups so using a variable group would be easy enough on the send side of things, but I would rather have it returning to a channel where I can get to it more easily. I normally keep my output fader bank on VCA when I'm mixing. Is there a good workaround for that? The Sansamp plug-in for the vocal is run on a split from the vocal channel. So I have the clean vocal channel, with a de-esser inserted, and then another channel from the same vocal mic preamp, with the Sansamp inserted (no de-esser). It sounds like they won't be delay compensated... how can I fix that? I realize I can manually delay one of the channels, but how can I find the needed delay? Thanks!! |
Hi Adam,
Example (not actual values - you'll still need to check these): Channel 1 with de-esser = 7 samples of process delay Channel 2 with Sans Amp = 9 samples of process delay Result: add 2 samples (9-7 = 2) to Channel 1 to align it with Channel 2. Sheldon |
Great!
That clarifies things a lot. I couldn't remember to right click the inserts area to find the delay. Thanks Sheldon!! |
I would point out that not all plugins report their latency correctly. It's good to do some testing if you want to be 100% sure everything is summing up nicely.
Edit: Also I think the connections between plugins (time slots?) take time, so if you have number of plugins in use in a row it might not be enough to just add the reported latency numbers together. How about it, Sheldon? |
So right-clicking on the individual plug-in gives you that plug-in's process delay, while right-clicking on the Inserts section gives the full picture. Sheldon |
Thanks Sheldon!
Delay compensation with backline delay | chuck goodwin | VENUE Live Sound Systems | 3 | 08-09-2013 07:54 AM |
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing | CNSound | macOS | 1 | 01-27-2012 11:10 AM |
Delay compensation Differs on SC48?:eek: | Zackdh89 | VENUE Live Sound Systems | 2 | 01-09-2011 05:22 PM |
Delay compensation- choice of 'Medium delay'? | dtmprod | Pro Tools TDM Systems (Mac) | 2 | 05-05-2010 11:00 PM |
Delay Compensation - Delay Monitoring when REC | Howardk | Pro Tools TDM Systems (Mac) | 2 | 06-18-2006 08:59 PM |
