Pro Tools 'An Error Occurred While Trying To Establish Ethernet Communication'
Hello,
I am trying to connect my Mc Control V2 into my Windows PC, running pro tools 10.3 & 12.4 I was able to get my MC Control to work perfectly on my macbook using the latest version of Eucontrol; 3.5 The MC Control works flawlessly on the macbook using both Pro Tools and Logic So I installed Eucontrol 3.5 on my PC, and made sure my firmware is up to date. After turning on the MC Control and setting my Eucontrol settings, the MC Control seems to be working as it switches focus on whatever application that it is on. So I open up Pro Tools and go to peripherals to set up the ethernet connection and Euconn connection. I get an error message when trying to connect either one. When I hit 'enable' on ethernet, I get a message saying: 'An error occurred while trying to establish ethernet communication. Please check all ethernet connections' When I hit enable on 'Enable Euconn' I get another message saying: 'Error occurred while trying to load the controller personality 'Euconn' So I figured maybe it's because I have my ethernet cable hooked into an Ethernet-to-USB adapter. So I then unplugged the ethernet cable that I use for my internet on the internet jack, and plugged in the ethernet cable that I am using for the MC Control, and plugged it directly into the built in Ethernet jack in the back of my computer. I did a system restart and proceeded using the same steps. I hit enable on the Ethernet option, however I get the same message. I then tried plugging the MC Control ethernet cable back into the USB adapter into a different USB port on my computer, and did the same steps again. Still the same error, no luck. I would like to mention that I used the same ethernet-to-usb adapter when working on my macbook, and it worked perfectly on the mac so it is not an issue with the USB adapter. I am running on windows 10, 64 bit with the latest version of Eucon:3.5 Could some one please help me out? I've been dying to use this awesome mixer!! |
Re: Pro Tools 'An Error Occurred While Trying To Establish Ethernet Communication'
Hi
Did you resolve this. I have just migrated to a pc from a mac pro and am getting the same message when trying to set up my C24
[B]Pro Tools 2018.4, C|24, X32 Rack, Win 10, Waves 10, Komplete 11, composers collection |
Hey there, I am super late on this reply however I still have not found any solution. My MC Control works perfectly on my MacBook, but for some reason just can't get it to work on my PC, which is where I do most of my work. Is there any one with a solution? pleaseeee |
I have an Artist Control working fine on PC, connected via a simple network switch(along with wired internet from my main network router. also have Transport and Mix units on my main rig(also PC) connected thru a Linksys wifi router(I also use the iPad Control app in that setup). No special setup needed, but do open the Peripherals menu and enable Eucon under the Ethernet Controllers tab
Have you made sure that the Ethernet selector in the EUCON Control panel is set correctly ?
I had the same problem.
First I loaded the Protocol - No Joy Then I added the registry entry - No Joy Finally I changed the 'Startup properties' to 'run as Administrator for all Users'. That resolved it |
That was it, run as admin, thank you!
Ethernet causes Lost communication error | apples | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-31-2014 08:49 AM |
Lost Communication -Error -6097/Pro Tools and 4 Processors/ | Boogie457 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-20-2010 08:07 AM |
PC losing ethernet communication message... | amiller | ProControl, Control|24, Command|8 | 1 | 02-15-2010 09:15 PM |
Unable to establish communication the SYNC box | Protools newest | Pro Tools TDM Systems (Win) | 3 | 01-02-2009 05:38 PM |
TLSpace TDM causes "Pro Tools has lost communication" error | jacobfarron | Pro Tools TDM Systems (Mac) | 3 | 06-18-2008 09:21 AM |
