  #21
Old 08-19-2010, 06:49 AM
Steve@ZooWest Steve@ZooWest is offline
Default Re: Problems with MIDI Sustain Pedal while recording
I hope MidiMerge is indeed the issue (I'll be checking it out too), easier to work around an issue if you know the root.
Thanks Chris ~
"Modern manufactured music is like art they sell at a furniture store."
http://www.weddingmusicproject.com/
http://www.weddingmusicproject.com/w...music-samples/
http://stevemillikan.com/
  #22
Old 08-19-2010, 07:23 AM
ChrisSimon ChrisSimon is offline
Yeah, let us know, if itīs on every system the same bug.... If, believe me, AVID will get posts from me as never before...
Isnīt it amazing, how nice the program appears, if you know how to handle that bug...Kind of inspiration...)
No, but serious... Write, if thatīs really the problem everywhere, so they can really get rid of that!!!!! - in one of the next updates...
Best
Chris
  #23
Old 08-19-2010, 08:14 AM
DigiTechSupt's Avatar
Originally Posted by jeremyroberts View Post
And since I work almost exclusively with midimerge disabled, I have never experienced this.
I only use midimerge mode when actually doing something that requires the function, such as a true merged overdub, or adding keyswitches or controller data. Then [9] right away.
IS IT REMOTELY POSSIBLE that a track you were recording had a #64 on at some point, and since you wee in [9] mode, the new #64 on was zapped by the old #64 off? Is there the slightest remote possibility of an operator error?
Considering that I have NEVER EVER experienced this, even when [9] is enabled, the fact that others had [9] enabled by default leads me to the possibility that a #64 off could have ben in the track, and since [9] mode doesn't overwrite, you get what you get.
Just thinking out loud, since random midi events simply make no logical sense.
That's exactly what I would think would happen - I've been investigating this for a long time and have always been able to solve it for any case I can get in front of. MIDI Merge on with sustain in the 'pre-merged' part could certainly be a factor here.
I'm very interested to hear what others experience with this. Maybe we have our 'ultimate' culprit and can find a way to engineer this so it works gracefully even with merge enabled..
Avid Audio Tech Support
Support FAQ
  #24
Old 08-19-2010, 08:31 AM
jeremyroberts jeremyroberts is offline
AATS: if you guys really want to engineer a better mousetrap: if you were able to code the pedal handling for midi punchins similar to how automation is written with a control surface, that would be a productivity boost. But the problem is that the pedal state is only on/off, and it's only 1-way. The pedal does not know the state the track is in. Is it possible for the software to be smarter than the pedal?
i.e. IF the track already has a pedal-on, and the next incoming event is a pedal-on, the redundant on-event is ignored (not written). ???
This way, the track does not get an extra pedal-on event written.
Same for pedal-off... some smart-guy look at "pedal logic" and how musicians use pedals and controllers while recording and overdubbing, in both midi-merge and destructive midi modes, would be a welcome improvement for a future update.
Thanks for keeping this on your radar.
J
--Jeremy
  #25
Old 08-19-2010, 08:58 AM
tonwurm's Avatar
tonwurm tonwurm is offline
it happens with newly recorded tracks, too - so itīs actually not a merge-thing, though this mode is active
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
  #26
Old 08-19-2010, 09:05 AM
Do you still have the problems, that sustain sometimes getīs off.... at new recorded tracks, when "merge" is off while recording?
  #27
Old 08-19-2010, 09:13 AM
tonwurm's Avatar
no - if I de-activate midi-merge, all is fine
my post was a response to jeremys thought, it could be an 'old' cc64 event from an earlier recording pass that switches sustain off, since merge mode does not erase any events - but as I answered to him, if midi-merge is activated, this issue occurs on newly recorded tracks too
Ultimate HDX
  #28
Old 08-19-2010, 09:16 AM
Well at least, that new tracks can be recorded without reediting sustains...
Nice to hear...
  #29
Old 08-19-2010, 09:18 AM
tonwurm's Avatar
Nice to hear...
perfect
Ultimate HDX
  #30
Old 08-19-2010, 10:04 AM
Hanswurstlsepp Hanswurstlsepp is offline
I can confirm that the sustain pedal problem doesn't happen if MidiMerge is off.
To be more precise, what just happened here during my tests is, that *sometimes* a CC#64 with val 0/127 is not processed by MidiThru.
This means, that the CC64 event(s) were recorded correct but at the moment while playing the piano-sequence into PT, the event was not sent thru to the VI or the ext. MidiDevice.
I always have a tracklane open showing the sustain-events.
This is 100% reproducable now after Chris Simon found this out - great Chris
But I have to do more investigations, cause if i remember correct, it also happened that the CC64 events weren't even recorded into PT (this was weeks ago or so)....but I might not remember it correct and so I will continue to make this bug as isolated as possible
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
sustain pedal problems in 6.4LE tromostheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-29-2009 09:24 AM
PT8, Sustain pedal, velocity problems while recording ChrisSimon MIDI 1 08-20-2009 05:23 PM
Problem with recording MIDI piano sustain pedal Chris7514 MIDI 5 06-11-2008 12:56 AM
Piano sustain pedal in recording Help!! Zownd Tips & Tricks 9 04-05-2004 02:21 PM
Sustain Pedal in Midi recording in PT LE Arya44 Tips & Tricks 1 11-09-2003 11:25 PM
