Old 09-19-2011, 01:28 PM
muso90 muso90 is offline
Unhappy ProTools was working but it is now "Unable to locate Digidesign hardware"
Error: "Unable to locate Digidesign hardware. Make sure your hardware is connected and turned on. Click "OK" when hardware is ready."
Hardware was originally working. Then came up with this error. We unistalled ProTools then reinstalled & problem was fixed. This happened again later, so we did the same thing & it fixed it again. Error happened again, we downloaded software updates which fixed the problem. But now the error has happened again! Have the latest update which hasn't fixed it.
When I unplug the Mbox USB connection from the computer then plug it back into the computer it says "Found new hardware" It tries installing it, but then comes up with "Windows was unable to install your Mbox. Windows could not find driver software for your device."
We've used the program fine, but now again suddenly it doesn't want to work. If anyone has any ideas, help would be most appreciated. Thanks!
Product Level 1: Pro Tools LE
Product Level 2: USB Interface LE
Product Level 3: Mbox (3rd Gen)
Software Level 1: Pro Tools
Software Level 2: Pro Tools LE
Software Version: Avid Mbox Drivers v1.0.19 for Windows (x86)
PC CPU Manufacturer: Dell
PC Model: Inspiron MXC061
RAM: 2.00 GB
Operating System: Windows Vista Home/Home Premium 32-bit (Service Pack 2)
Old 09-19-2011, 02:06 PM
Default Re: ProTools was working but it is now "Unable to locate Digidesign hardware"
Personally, I would dump Vista and go with Windows 7 64 bit. Meanwhile, did you do all the system tweaks, including turning OFF the power management feature on all USB ports?
Old 09-19-2011, 08:07 PM
zedhed's Avatar
zedhed zedhed is offline
Frankly Vista is a pig of a system. You would be better off with XP if you don't want to go for Win7 although I agree with Albee that would be the best way to go.
Read through this link, it may be of some help; Some of it may not be relevant but some might.
http://duc.avid.com/showthread.php?t...ghlight=zedhed
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 09-25-2011, 04:12 AM
lberrios1962 lberrios1962 is offline
MUSO90..I'm running Protools LE 8.0.5 with an Mbox3 on Win7 64bits and I'm having exactly the same problem. Upgrading to Win7 will not fix the problem. I'm still waiting for somebody with the solution. I also had turned off all the USB power management plus I did all the tweaks for Win7 and still doesnt work.
I had work with Protools for more than 20yrs and never had any issues until version 8 came to the market.
ASUS P9X79 DELUXE, Intel i7 3930K, 32GB DDR3 Corsair Dominator, 2 SATA 1TB 64MB HD, CORSAIR H80 Liquid Cooler.
Mac mini 2.3GHz Quad Core Intel i7, 16GB memory, 1TB Fusion drive, 1TB Thunderbolt external HD.....Running PT11
Old 09-25-2011, 07:10 AM
I just re-installed the Mbox drivers and its working now. Will see for how long
Old 09-25-2011, 08:46 PM
zedhed's Avatar
I think you need at least version 8.04 with Vista, but I would go to 8.05 if you haven't already done so;
http://avid.custkb.com/avid/app/self...p?DocId=393651
And install latest drivers to go with 8.05;
http://avid.custkb.com/avid/app/self...p?DocId=379411
Re-install drivers with interface turned off then reboot with it turned on.
Once 8.05 installed run plugin updater;
http://avid.custkb.com/avid/app/self...p?DocId=362895
I've found at least on my system, that switching hardware Interface on before booting computer, and shutting computer down before turning Interface off helps avoid the problem of losing driver communication with computer.
HD 96I/O
Old 10-08-2011, 11:06 AM
I just installed a separated USB card just for Protools and every problems that I had before, including "Unable to locate Digidesign hardware" are gone.
Try getting a USB card just for Protools. That will fix your problem.
Also you don't have to remove and re install Protools. Just got to Program files(86)/Degidesign/DAE/Drivers and find the Digi logo. Click on the logo and this will re install the drivers without removing the whole software.
Old 10-10-2011, 05:51 PM
jedsaje jedsaje is offline
well i have been having this problem and idk why. i have always had this problem with my windows pc
i had an old e mac with the digi 002 (firewire) and worked great for years.
i bought a new pc with windows 7 64bit way over powered for the minimum and the pc doesnt make that sound you normally get when you plug anything in the usb or firewire port.
any help for little ol me??? lol
Old 10-10-2011, 06:26 PM
zedhed's Avatar
Which version of PT are you using?
Post a Sandra Report.
- Please - Use SiSoftware's Sandra Lite application to generate a full system profile:
www.sisoftware.co.uk
Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
HD 96I/O
Old 10-11-2011, 02:59 PM
GTrumpet GTrumpet is offline
Angry Re: ProTools was working but it is now "Unable to locate Digidesign hardware"
We bought an Mbox 3 and have been trying to use Pro Tools LE 8.0.5 on a two different Windows 7 64-bit systems since July.
Initially we installed on a laptop and it worked for a while, then we got the "Unable to locate Digidesign hardware" message. We tried everything we could find here, reinstalled a number of times, etc., then gave up and switched to a different, more powerful system (the first one was no slouch).
Once again, PTLE worked for a couple of weeks and then yielded the same error message again. So I tried everything I could find here and that made no difference.
We broke down and paid for a support call. The tech spent about 45 minutes going through everything, checking for the same stuff I had already fixed. Then he too gave up and issued an RMA for the Mbox 3.
I hope that fixes it.
He said that they did have a batch of bad hardware and he also said that some of the Mboxes were very sensitive to being unplugged from a USB port while the system was powered up - apparently doing so may damage the unit.
"Unable to locate digidesign hardware" Mbox (original) ProTools LE 7.4.2 Mac OS X sharpd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 04-27-2012 12:11 AM
Digi 003 "Unable to locate digidesign hardware" - Broken Firewire? mpeddle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-03-2011 06:43 AM
"unable to locate digidesign hardware" message on pro tools 9 echalk Windows 9 08-29-2011 03:37 PM
"Unable to locate digidesign hardware" windows 7 MBOX3 StaticVoid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-21-2011 02:13 PM
"Unable to locate digidesign hardware" Digi 002 - but with a curious twist. Honest Gentleman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-14-2009 05:08 PM
