Show used Automation
What is your workflow if you want to make small adjustments of existing automation. Lets say you used 5 different parameters in a track for one scene.
Do you ctrl + cmd + click on each individual plugIn parameter or is their a way to show all used automation at once?
MacOs 11.6.7, RME Fireface UC, PT Ultimate 2022.9 Mac Pro 6.1/12-core,64GB RAM, Aja t-tap Béla Brandes | www.bbsounddesign.de |
Re: Show used Automation
Enable preview mode, change settings the way I prefer, write to selection, exit preview mode. This only works on static automation though as it's written to the length of your selection. Ultimate only I think.
Note: when there is no selection and you write anyway, the entire track automation is removed, so be careful. Also, only touch the plugin/parameters you want to change. Everything you touch will be written. |
Thanks for your reply! The way you describe is the way i make static automations for scenes too.
My question is more about the next step/ path. Lets say you jump back to a scene which includes automation already and you would like to see and adjust alle the used single automation lanes.
That would be a nice feature and something I've wanted for ages. Something like 'show all written automation' and the lanes with automation written to them spill out under the selected track, very useful. We can only dream... They did bring in the feature where used automation parameters go highlighted orange in the track menu, which is useful. But I've found it's quite flakey and doesn't always work properly. So, in answer to your question AFAIK there is no way to do what you'd like, other than opening each used lane individually. There's room for a lot of improvement in the way PT handles automation I think. You should be able to Tab and select between automation points as well.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
For crying out loud yes.
~Will |
Once in a while I wonder just how many snapshots or how much automation a plug-in has, so I open up the plug-in either visually or on a surface and shuttle through the area to see how many knobs wiggle.
Nathaniel Reichman Producer/Re-recording Mixer - New York Nathaniel Reichman | IMDB | LinkedIn |
I don't believe there is a way to do this, but I can see how it would be useful for tweaking things to be less static after setting a snapshot for automation rather than going through and control+command clicking on individual parameters. Or just to see what all is actively automated when either revisiting a section or getting something someone else has worked on. Which makes me realize this would actually be useful just for clearing out existing automation that might already be written when getting something from a video editor. |
Sometimes its easier or quicker to write automation with a knob or fader, sometimes easier and quicker to draw it in or nudge the existing automation. If PT automation was simpler to access and manipulate in the ways described, it would help both scenarios. The one thing I do know about us Sound people is we all work in different ways and there is nothing wrong with that.
Hi Nathaniel - as you know, I'm a music engineer and I can't tell you how many times I've wished for a way to display all used automation lanes on a track - it can be maddening to hunt through automation parameters to see what's going on - it's very common for me to have say 9 or 10 parameters on an eq automated and 'gliding' from one setting to the next, or to have a bunch of sends automating at a musical scene-change - if I need to edit 4 of those parameters, but not the other 5 or 6 it's a major PITA. If I could just quickly display them all quickly it would be very easy to see what's going on.
In post, where you're automating every parameter in a plugin I could see how difficult it might be to display all this, but still - a much-desired feature here.
If Rich Breen needs this feature, then I withdraw my argument!
And it's true, everyone does work in different ways. Pro Tools is not the only app that has hundreds or thousands of keyframe parameter changes over time. It would be interesting to see how this problem is addressed in Premiere, After Effects, Unity and Maya. Maybe there's something clever in that world that could be brought here. Some plug-ins in Pro Tools would fan out into the Edit window over a vast graphic space. That might be why Avid hasn't implemented this.
S3 Trim Automation Doesn't Show | stangroom | Avid S1, S3, Dock and Control App | 6 | 05-09-2017 07:54 PM |
Show all used automation in edit view? | amagras | Pro Tools 10 | 8 | 04-24-2015 01:08 PM |
show used automation on all tracks and workarounds | amoretam | Pro Tools 9 | 4 | 01-13-2013 08:31 PM |
Show Hide Automation Lanes - Shortcut ? | Tomy DeClerque | Pro Tools TDM Systems (Win) | 0 | 02-07-2009 04:06 AM |
show all automation? | Khatru | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-10-2007 07:16 PM |
