Old 12-06-2004, 05:01 PM
bH101 bH101 is offline
Default What\'s the trick to using the SEARCH function ?
Whenever I do a search for specific phrases, words, or error codes, it never fails that the search results have nothing to do with the keywords that I have entered. Is anyone else having difficulty finding things using the Search Function? Is there some trick to having the results more accurately reflect the query? Thanks.
G5 Dual2.0 OSX 10.3.4 Digi002R PTLe 6.4? Logic 5,6,7 Reason 2.5
G4 Powerbook1.5 OSX 10.3.4 Digi MBox Ptle 6.4
Old 12-06-2004, 05:07 PM
lwilliam lwilliam is offline
Default Re: What\'s the trick to using the SEARCH function ?
Try using quotes around the phrase. "mBox outputs" produces a way different response than mbox outputs (without quotes). The quotes ensure that the entire phrase is in the search results, not just the individual words - which could be separated by a paragraph or more.
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 12-07-2004, 12:00 AM
Using Quotation marks at best yields one or two finds that come close. More often than not, there's nothing remotely related. And why is the defaut "Newer than 1 Week". Aren't most of you looking for things that are much older than that? I appreciate this place VERY much and feel the need to make some suggetions that might help most of the users here. The Search function is pretty crucial , yes? am i the only one here who is frustrated with the search results?
Old 12-07-2004, 12:11 AM
I've found that putting a PLUS sign before the keywords has done the trick.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 12-07-2004, 12:17 AM
I just tried
+mmc only option for midi sync?
+mmc only option
+mmc
All three yielded 0 finds.
Old 12-07-2004, 12:19 AM
We are referring to the "Search the DUC" search area , yes?
not the "Search the Answerbase".
I just had the same results doing the search on the "Search the Answerbase" page.
Old 12-07-2004, 12:25 AM
it would appear that the easiest solution is to simply Post a Question..
.. and watch as the incredibly selfless masters of software appear and answer with uncanny aptitude.
Old 12-07-2004, 01:27 AM
Uh.. let's see.. I just searched for +mmc and left everything at the default and it returned 4 posts (probably 5 with this one now).
Which Browser are you using.. use Internet Explorer.
Previous thread with search issues under OS X
Rail
Platinum Samples
Problems with search function in ver 1.1 billunatic Avid Scorch (iOS) Forum 4 01-05-2012 11:45 AM
This Forum's search Function is better off DEAD 25ghosts Pro Tools TDM Systems (Mac) 3 12-23-2006 12:14 AM
is the search function not working????????? gwattaloopy1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-23-2006 11:36 AM
Search function Joe Evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-01-2005 05:35 AM
What's up with the DUC search function? Amerihudge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-25-2003 02:01 AM
