How to Import Markers and specify Timeline Oriantation.
I'm doing a project involving 14 hours of audi being loded from DAT tapes. I'm having my assistant digitize in the other studio
while I start editing. The problem is, every session he gives me puts the Memory locations at the head of my timeline. I can get the transfer to put the audio in a specific location on my timeline but not the markers. They become disassociated. Is there a way to move them? we're talking like 100 marker locations for every DAT tape. |
Re: How to Import Markers and specify Timeline Oriantation.
Markers are on a track like everything else, so you can move them.
"My ego comes pre-shrunk" - Randy Thom |
If, for example, your audio is at hour 7 and your markers are at hour one, you can use the the session start time to realign your markers. Change the session start time to hour one and choose maintain RELATIVE TC. Your audio and markers will be aligned at hour one. From there, you can change the session start time to whichever hour you need it to be and choose RELATIVE again.
Or, as Airon mentioned, place your cursor in the marker track somewhere past the last marker, hit Shift-return to select the entire track to timeline start, cut, paste to hour seven (or whatever). Hopefully, one of these two methods should do the trick.
Pascal Garneau | IMDb |
I know I can mov ethe markers one at a time but can I grab like 100 of them at once?
I wasn't able to figure it out. with the session start thing.... I'll try that this morning. Thanks |
OK, I got it... here's what I did.
I opened up the session that DAT#6 was loaded into. I then reset the Session start time to match the master Edit session I was already working on. Then I tried to select the audio and all 132 Markers and spot them to Hour 6. It wouldn't let me spot but would let me cut and paste the marker locations. Then I saved and imported into my editing session. Thanks for the tips. |
To edit 'Markers' on ProTools Timeline | critictalk | Getting Started | 2 | 05-16-2013 10:07 AM |
Recording Problem w/ Timeline Edit Markers | tickles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-11-2010 05:13 PM |
NEED HELP QUICK, "MARKERS MOVE WITH AUDIO DOWN TIMELINE | dkstudios | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-02-2008 04:27 PM |
set timeline selection to match space between markers? | EnzymeX | Tips & Tricks | 5 | 01-31-2008 11:36 PM |
Markers get deleted in the timeline! | PT Weenie | Post - Surround - Video | 4 | 12-04-2006 01:20 PM |
