PRO-52
GOT MY 002 BACK IN DECEMBER EVERYTHING IS FINE WITH THAT THE THING IS I'M NOT SURE HOW TO USE THE PRO-52 PULGIN? I'M RUNNING PRO TOOLS ON A G4 867/512, ALSO I HAVE A MPC2000XL, KORG TRITON IF SOMEONE CAN HELP.
[img]images/icons/smile.gif[/img] |
Re: PRO-52
I can't remember if the Pro 52 is Direct connect, or the Digi version. I think it's the latter, and assuming that, you insert the plug in on an AUX track, then create a midi track, and select the Pro 52. Select REC enable on the midi track, and you're away.
G5 Dual 1.8 /1.5 Gb Ram OSX 10.4.7 PT LE 7.3 cs1 DIGI 002 Waves Ren Sony Bundle Soundtoys-arama NI Komplete 3 |
Re: PRO-52
Re: PRO-52
>connect, or the Digi version. I think it's >the latter, and assuming that, you insert >the plug in on an AUX track, then create >a midi track, and select the Pro 52. >Select REC enable on the midi track, and >you're away. just to expand a little cuz this still looks a little confusing to someone not familiar... like he said, insert the plug on an AUX track, create a midi track, then in the output of the midi track you will now be able to select Pro-52 as the output. rec enable then you're good. btw, this is all in the manual... je |
