Old 11-26-2011, 02:47 AM
Gravy Gravy is offline
Question Focusrite & novatin plugins with protools
Hey guys. Having an issue with opening some of my plugins with protools. Most of my plugins are in the usual audiosuite location. But i cant find my novation bass station and focusrite plugins through pro tools and cant locate them on my computer to move them into my digidesign folder. But every time i open ableton. There they are. Have i overlooked a simple plugin search or something in protools? I am quite new to pro tools.
Old 11-26-2011, 03:32 AM
PD-John PD-John is offline
Default Re: Focusrite & novatin plugins with protools
Are you sure you've got RTAS versions of your Focusrite plugins and BassStation? If you got them bundled with a Focusrite interface then it's likely they're AU and VST only.
Old 11-26-2011, 10:27 PM
Ah right. How do i find them in my system & can i convert to RTAS versions? Also can i use my digidesign plug-ins i have on pro tools with ableton? Thanks for your time PD-John
Old 11-27-2011, 05:03 AM
I'm not sure where non-RTAS plugins are kept, but if you haven't already, try typing the plugin name in the Search Bar. Or search by file extension - from memory, AU is .component and VST is .vst.
You can convert VST plugins to RTAS by purchasing a wrapper such as this one by FXpansion: http://www.fxpansion.com/index.php?page=15
The stock Digidesign plugins will be RTAS only, so you won't be able to use them with any other DAW.
Hope this helps
Old 11-28-2011, 05:13 AM
Yes that does help. Slightly disappointing but at least i know now. Thanks man!
Old 11-28-2011, 06:40 AM
If i convert the VSTs to RTAS, will i still have the VST version to use with ableton?
Old 11-28-2011, 07:10 AM
danander11 danander11 is offline
Yes.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Focusrite Liquid Mix and ProTools 9 playground_strifer Pro Tools 9 1 03-25-2011 04:20 AM
Problem Focusrite Plugins hanare Pro Tools TDM Systems (Mac) 3 12-11-2003 05:07 PM
Focusrite Forte / Eventide Reverb Plugins BillSmith Pro Tools TDM Systems (Mac) 0 12-06-2003 07:36 PM
focusrite d2/d3 plugins vs. red 2/3 hardware wellversed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-25-2003 03:58 PM
IS ANYONE USING FOCUSRITE PLUGINS? Pete Weaver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-21-2002 07:59 AM
