quick question - Mbox Mini question - i forget
I had an M-Box Mini but switched to an 002 a while back. My buddies are in from out of town and want to record their rehearsal so he was asking about using the Mbox Mini to do a stereo record. i forget if i can set up 2 mics ( i have a cable to convert one of them to 1/4" ) but my question is will it actually take the 2 inputs and let me record the 2 different singles on the MINI ? i dont recall if it allowed me to do it way back when i used it
any help refreshing my brain would be greatly appreciated. thanks |
Re: quick question - Mbox Mini question - i forget
The second channel is a line/di input. No mic pre-amp.
The first channel is mic/line/di. So, yes, you can do stereo recording as long as the second channel is not a mic. It can be a guitar or line level. You would need a mic pre-amp to do stereo mics. You could use the mic pre-amps on a mixer.
MBox 2 Pro connected to motherboard 4 pin firewire port Dell Inspiron 9300 laptop 2.0 gHz Pentium M 2 gB ram Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter Roland 700SX stage piano Studio Projects C3 mics Melodyne Plugin Dual Boot: PTLE 8.0.1 on Windows 7 Enterprise 32 bit PTLE 8.0.1 on XP Media Center SP3 |
if i pulled 2 outputs from the rehearsal mixer? i should be able to run the line inputs into it then. i could definitely try that.
thanks |
That should work.
thanks so much
quick question on mac mini | gprok | macOS | 5 | 04-22-2013 01:05 PM |
M Box 2 Mini. Quick question. | harry3232010 | macOS | 1 | 09-27-2011 08:02 AM |
Downgrading MBOX 2 to MBOX mini (Quick question) | Mista808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-09-2011 08:29 PM |
Quick Question- remaping with Mbox2 Mini | jmitchell1532 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-07-2009 11:36 AM |
Quick Question - MBOX MINI | ld_neil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-12-2007 04:50 PM |
