Install PT 12 & PT HD9 on same drive?
Howdy,
I'm PT HD9, I want to try 12 vanilla as they say...can I install PT 12 on the same drive that already has PT HD9 on it - without screwing up my world too bad? There's other drives on the Mac so I could put it another drive if I had too but it's an SSD and I'd like to do it. It'll be two separate licenses, I don't have to surrender HD9, I'm just additionally buying PT12? I suppose I could always reinstall HD if something gets corrupted. Can I do it? Thanks! Last edited by acmost; 03-13-2017 at 03:15 AM. |
Re: Install PT 12 & PT HD9 on same drive?
I wouldn't and here's why; 9(and everything from 10, back) use RTAS and 11/12 use AAX 64 plugin formats, having tons of extra folders for all the versions of every plugin is just not efficient. I would clone the system drive to another drive and install the clone. On that drive, I would uninstall everything to do with PT9 and all your current plugins. Then install 12 and do a little testing to make sure it runs and sees your interface. Then install the newest versions of all your plugins. Doing this means that you can't screw up your current setup(that is probably running nicely). I'm a firm believer in "if it ain't broke, don't fix it". But I am also a firm believer in trying the latest(so I ALWAYS have a backup plan)
Danggit...makes sense for sure. Thanks! Looking for the easy way out
The issue also is will PT12 work with your current OS X?
I doubt it considering PT12 wants a minimum of OSX 10.8.5 and PT9.0.5 added public beta support for OSX 10.7.x
I figured I would try, I’ve heard somebody has had success…just not supported.
Thanks for the replies. |
One of the things you're going to run into is what PT10 users run into when using anything newer than OSX 10.9.x and that is blank insert menus until you hover over them. Not to mention even installing PT9 on a new OSX. And whatever you do do NOT use Migration Assassin (Assisstant) to bring programs over; it's only good for data and nothing more.
Before you do that make a clone of your working system so when, not if, but when your system takes a dump you can recover and get back to work with little time lost. Aggravating - yes but having the clone sure beats being down.
Install PT on drive other than C:\ | taylor4814 | Windows | 2 | 02-12-2012 04:36 AM |
Please help: Need to install to a different drive | ganeshncm | Pro Tools SE and Essential (Win) | 1 | 07-31-2011 11:14 AM |
help, cant install a cd-r drive? | maskedman72 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-10-2006 03:29 PM |
INSTALL ON MY C DRIVE AND STORE ON D DRIVE? | H-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-18-2001 09:33 AM |
install on different drive | spotta | Digidesign Hardware & Software | 1 | 12-22-2000 01:56 PM |
