Old 11-11-2011, 08:01 AM
kingtinker kingtinker is offline
Default Can't edit velocity only anymore? Notes copying with velocity data...
In Pro Tools 10, I'm trying to copy and paste velocity info on a midi track and NOT copy the actual note events, which is something I used to do all the time in PT 9 and before. But now I can't seem to unlink the velocity data from the notes they're tied to. Anyone have any ideas?
Old 11-11-2011, 12:38 PM
Default Re: Can't edit velocity only anymore? Notes copying with velocity data...
I believe the only way to copy and paste Velocity events is to use Beat Detective Groove Extraction.
Aaron Mulqueen - 001 HD Native
Old 11-11-2011, 01:45 PM
Are you kidding me? Really? I used to copy and paste velocity all the time. What happened?
Old 11-11-2011, 03:30 PM
Velocity copy and paste has always been DigiGroove Extraction.
Old 11-12-2011, 04:19 AM
Ant B Ant B is offline
This can't be right. Well - it shouldn't be right if it is. That's just silliness. To be honest, though, I've never copied velocity without the notes (never wanted the same velocity curve for different notes) so I don't actually know if, when copying velocity curves before, I was also copying the notes since ultimately wherever I flew velocity the same notes were present. But..this just sounds ridiculous if true
Old 11-12-2011, 10:53 AM
I stand corrected, Pro Tools have never supported the function of copy and paste MIDI Velocity events without Note events being attached. The only supported method is DigiGroove Extraction.
Copying notes without erasing already set velocity Nightworker Pro Tools M-Powered (Win) 7 06-15-2011 08:16 PM
Toggle Notes to Velocity? Blank Frank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-02-2007 03:27 PM
Toggle between notes and velocity Blank Frank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-02-2007 01:12 AM
Play Midi Notes When Editing Velocity? Raccoon Pro Tools TDM Systems (Mac) 1 11-20-2003 08:03 AM
Play Midi Notes When Editing Velocity? Raccoon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-20-2003 05:09 AM
