Old 03-08-2018, 06:47 AM
Maro Records's Avatar
Maro Records Maro Records is offline
Default New knob response for the Dock
... for me is much worse !!!
the previous action for knobs was great, excellent and I loved so much ...
Now it's difficult to do small changes in a very accurate way.
Please, reverse to previous action, or give us a choice...
Maro,
http://www.marorecords.com
Old 03-08-2018, 11:34 PM
Anthony_Anz Anthony_Anz is offline
Default Re: New knob responce for the Dock
Maro Records, the dock knobs previously had a slower acceleration which felt like you could make finer adjustments. I know it's an extra step but you can always hold down CTRL while turning the knob to make fine adjustments. (except for PAN, for some reason holding down CTRL does not slow down that acceleration... )
Old 03-09-2018, 05:47 AM
The beauty of previously acceleration mode was possibility to make finer adjustments and more radical movements wthout feelining any compromisses. It was done excellent and I wonder how it could have been spoiled and why ??? In professional world all is about precision nad easy way to small movement.
I don't want to hold down CMD (CTRL) for that because it's tiring and I usually use both hands to control 2 parameters at the same time. Well, I do not want to explain even these things, because it's obvious for people dealing with it professionally ..
Anthony, last update of Eucon is a large step down and please, do not try to convince me that it is not...
Eddie, please, if you have no intention of doing anything about it, just help how to go back to the previous version? Do I have to go back with firmware of a Dock?
Maro,
Old 03-09-2018, 11:05 AM
I'm well aware of the inconvenience of holding down CTRL, I was merely trying to give you a temporary work around. I'm sure, with enough feedback, it will be revisited.
Old 03-10-2018, 12:55 PM
Well, it looks like I’m along here
Hey ! Dock users ! Are you there? Are you happy with the new update?
E.g. Controling pan is like a joke now .
Please, say something guys! Do you like it ?
Maro,
Old 03-10-2018, 02:05 PM
BScout BScout is offline
I like everything but Pan. I think there is something genuinely wrong with Pan on the Dock. It does not respond anything like the Artist Mix knob on pan (which generally I use instead of the Dock for panning.) I also don't think it works like the S3 knob (though I'm not sitting at that today. I think I would recognise something this off.) Eddie, could you look into this?
Non-linear (acceleration curves in digital speak) knobs and faders are pretty standard for professional hardware. Except for Pan (which appears to be broken), turn slower for finer precision. No need to press "control". I have no problem hitting the exact same precision as using a mouse (both fine and major steps)
(btw, I don't think fine control works with Eucon -- "command" on Mac. It doesn't seem to work with anything on my Artist Mix or Dock)
Old 03-10-2018, 02:35 PM
Previously pan worked great for me. Sends also were better.
For me overall action of knobs were as it should be.
I dream about possibility to back firmware on a Dock and Eucon to 3.7 and never touch it. Now using knobs on a Dock is big suffer...
Maro,
Old 03-10-2018, 07:23 PM
Sean Bombz Sean Bombz is offline
Pan on the dock is definitely wonky. Definitely couldn’t use it for automation.
Sean Bombz
Mac Pro late 2013 3.5GHZ 6 core 64g ram
Mojave 10.14.5
Pro tools 2019.5
Apollo x 16
Apollo 16 mk2
Apollo twin mk2
Avid S3
PT Dock
PT control (iPad)
eucon 2019.5.1
Old 03-12-2018, 02:02 PM
...Definitely couldn’t use it for anything...
It's a shame. Now to set the exact value I need to catch the mouse...
Surface simply became useless...
WHO APPROVED THIS UPDATE ???
Maro,
Old 03-13-2018, 07:48 AM
So is it safe to say that the biggest complaint about the kinetics change is just how affected PAN? How do you guys feel about EQ, DYN and insert parmas? I'm not having too much difficulty with other params.
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Avid S1, S3, Dock and Control App 0 10-01-2016 08:20 AM
002R Volume knob=Control24 Volume knob?? Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-07-2010 04:04 PM
Message/responce for member "SNAPPER" aka John. DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-10-2008 07:08 PM
System responce is very slow Jstil Pro Tools TDM Systems (Mac) 4 05-02-2007 01:33 AM
Midi Responce Armando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-19-2000 12:59 AM
