Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-07-2007, 11:29 PM
Ninia Ninia is offline
Default Pro Tools 7.4 works on Leopard (warning, upgrade gotcha)
Hello all
Just a quick note to say that PT 7.4 works on Leopard.
HOWEVER, I did run into an interesting problem when I went to run the upgrade. The upgrade would fail with an 'Install Failed' error. I don't know what caused the error but I did notice that the 7.3.5 version of PTMP was not in the Digidesign folder anymore. As I was now faced with possibly having to completely reinstall PT from the disks I decided to try the uninstaller that came with the 7.4 download. After running the uninstaller I then reran the 7.4 installer, it installed with no errors this time. Runs fine. I have just loaded in one of my older vocal lesson wav files and did a couple of quick edits, no problems.
One cautionary note; When 7.4 was installed I found that all of my previous session files had been wiped out. I'm not sure if this was a normal function of the uninstaller but I would advise that you copy any important session files to a separate disk that can be unmounted from the computer prior to doing your upgrade. Thankfully none of my session files were vital, they had all been completed and the mastered files had been previously off-loaded.
Ninia
Old 11-08-2007, 04:17 AM
jbmelby jbmelby is offline
Default Re: Pro Tools 7.4 works on Leopard (warning, upgrade gotcha)
FWIW, PTMT 7.4 installed with no issues on my Mac Pro running Leopard. I did get a message that my pace files had been incorrectly installed, but after the restart, everything worked perfectly. And the installer did not delete any of my session files.
Mac Pro 8-core 2.4 GHz, 10 GB RAM, Mac OS 10.7.1, PTMP 8.0.5, M-Audio Firewire 410 (driver version 1.10.3)
Old 11-08-2007, 07:55 AM
spkguitar's Avatar
The installer should not erase any sessions. The only time an installer would erase sessions is if you mistakenly have them stored in the temporary Digidesign Databases folders that are created by the program.
Here's my cautionary note; there's a serious issue with thread prioritization in Leopard that may cause performance issues in Pro Tools (and honestly, any other program). It's why they are recommending waiting until it gets fixed. Just something to watch out for.
Old 11-08-2007, 06:11 PM
[/QUOTE]The installer should not erase any sessions. The only time an installer would erase sessions is if you mistakenly have them stored in the temporary Digidesign Databases folders that are created by the program.
[/QUOTE]
Ahhhh, thanks for clearing that up, that's exactly where they were being stored. (Is there a location where session files should be stored? I can't find a specific statement regarding this in the manuals)
[/QUOTE]Here's my cautionary note; there's a serious issue with thread prioritization in Leopard that may cause performance issues in Pro Tools (and honestly, any other program). It's why they are recommending waiting until it gets fixed. Just something to watch out for.
[/QUOTE]
So far I haven't experienced any problems, however I do all contract work on a Tiger Partition so that isn't a concern at this point. I maintain a separate partition for Leopard and experimenting with compatibility between various programs. The only program that I've seen behave funny was iTunes getting stuck on, and repeating, a single note when the screen blanked out. Beyond that everything has been working quite well in Leopard.
Ninia
Old 11-08-2007, 10:47 PM
spkguitar's Avatar
Anyplace but there.
And where is the specific statement that says that's where you should store them? I'm just curious what made you think that was the place to put them.
The Digidesign Databases are temporary folders created by the program on every hard drive connected to the system, and usually are deleted when upgrading software. It is also recommended to delete them manually from time to time, as they may become corrupted. It is never recommended to store sessions there. Ever.
More information about the Digidesign Databases can be found starting on Page 7 of the DigiBase Guide (also available from the help menu in the program). THough it never explicitly says "don't put your audio sessions here", most of the information implies that these folders are for the program's use only.
It is recommended that session files be stored on a separate physical disk. That recommendation is made in the Getting Started Guide for all products, the Pro Tools Reference Guide, on every compatibility page, and every general troubleshooting recommendation.
Old 11-09-2007, 12:34 AM
[/QUOTE] I'm just curious what made you think that was the place to put them.
[/QUOTE]
That's easy, my rational for putting the files there was based on an assumption that the Database Engine needed the session files to be located in the Databases folder in order to 'see' those files.....okay so that turned out to be wrong <sigh>
[/QUOTE]The Digidesign Databases are temporary folders created by the program on every hard drive connected to the system, and usually are deleted when upgrading software. It is also recommended to delete them manually from time to time, as they may become corrupted. It is never recommended to store sessions there. Ever.
[/QUOTE]
So I discovered......
[/QUOTE]More information about the Digidesign Databases can be found starting on Page 7 of the DigiBase Guide (also available from the help menu in the program). THough it never explicitly says "don't put your audio sessions here", most of the information implies that these folders are for the program's use only.
[/QUOTE]
And I very specifically bought a separate drive for that purpose. When I mounted it and pointed a new session file at that drive I discovered that a Database folder had been created on that drive as well, which led me to think that the Database folder was the natural place for a session file. As you yourself pointed out there is no information which states not to put files there.
Thanks for pointing out where my error was. I'm happy that it wasn't a bug.
Ninia
Overall my Pro Tools 7.3 works freat, why would I upgrade to PT 10? GMP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-17-2012 03:10 PM
Pro Tools 7.0 LE upgrade to Snow Leopard Pais_man Pro Tools 9 10 02-22-2011 09:17 AM
Pro Tools 7.0 LE upgrade to Snow Leopard Pais_man Pro Tools M-Powered (Mac) 1 02-11-2011 10:32 AM
Pro Tools LE 8 + Snow Leopard + Mac Book Pro 17'' + SSD Upgrade ? Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-22-2010 09:37 AM
Warning: New pro tools upgrade renders b4 useless billkahler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-22-2009 10:21 AM
