Pro tools 8 M-Powered, which audio interface
Good evening,
I have had a search and can't seem to find an answer. I have just moved to a new school to teach music technology and have found that they have 6 PC's with Pro Tools 8 installed on all of them but only 1 m-audio interface for recording. We need sequencing software and I had thought about buying Cubase but this was before knowing we had 6 copies (only thought we had 1), is Pro Tools usable to create a piece only inputting MIDI (all that is allowed for coursework). Question 1. What is the best/cheapest hardware that will enable me to use Pro Tools on the PC's with MIDI keyboards we need 5-6 bits of hardware. Or do we even need hardware, is there a work around? Question 2. Is Pro Tools user friendly enough for a sequencing project with only inputting notes via a MIDI keyboard and changing them on screen. Thank you very much for your help, Neil |
Re: Pro tools 8 M-Powered, which audio interface
Hello Neil. I have been using an m-Audio NRV-10 FW mixer as an interface. I only needed it because I use analogue inputs from my keyboards as well. I also use an fasttrackpro usb interface. There is little latency when using 2 or 3 tracks but it creeps up with each track. Newer versions of protools don't require an m-audio interface, but the crossgrade is quite expensive. There are some m-audio midi-controllers that serve as the interface, as well as some non-m-audio FW midi controllers. It depends on how fancy you need your midi controller to be. I have not used cubase, so I can't comment on what you would be changing to, but the voices available on protools 8.05 are nothing to be sneezed at.
Avid! I bought LE, an M-Audio interface, I ain't buying M-Powered as well! Upgrade? | RhysC | General Discussion | 9 | 07-23-2010 03:56 AM |
pro tools 8 m powered and maudio 610 interface | barry1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-09-2010 11:28 AM |
Pro Tools 8 M Powered and M-AUDIO fast track interface problem when recording | olpolo | Pro Tools M-Powered (Win) | 0 | 01-08-2010 05:21 AM |
Which interface best for M-powered Pro tools | musicery | Pro Tools M-Powered (Mac) | 13 | 11-16-2009 09:58 AM |
New M Powered Interface for Pro Tools | froyo | Pro Tools M-Powered (Mac) | 0 | 10-07-2006 10:58 PM |
