Drum Replacement plugs
I've asked this before, maybe a year ago and decided to wait it out to see what might come in this area of plug-ins. It looks like drumagog 5 is out and SS Trigger, and there may be some others available too that I don't know about. I'm curious what people think about them in use? I know that drumagog 4 seemed to have issues with alignment... Have these really been resolved. Trigger seems simple and to the point, but how accurate is it? Do they all have midi output?
I don't replace a lot of drums, I tend to go for a more raw sound, but on occasion I'll work with a poor drummer who needs a little tweaking here and there, and I usually just use clean samples of thier recorded kit, so no big studio samples are needed. So please let me know what you think of different replacement plugs based on features and not the included samples. |
Re: Drum Replacement plugs
hay sky,
trigger rocks, verry accurate; midi out, not so much (pt prob, not slates...) b.o.l. e
ihatetyping |
What he said.
Trigger. You can get a stripped down version that doesn't include a ton of samples and easily drag your own in. It's fast and easy.
Brian Steckler, Producer |
Slate trigger.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
Yah, Trigger works amazingly well. They really nailed the detection algorithms and the Suppresion function is quite brilliant and effective.
Steven Massey should have his revamped Drums-to-midi plugin out soon. For midi, it's the cat's pajamas.
I use Drumagog 4 and Soundreplacer. Works great for me.
i used to use sound replacer
Trigger is much Quicker and More Accurate |
Soundreplacer will give you the machine gun effect on fills as it can only replay the one and only sample that it holds. This also results in not being able to capture any of the dynamics of the original performance as there are no lower dynamics samples available. The newer tools are far more realistic sounding.
Massey DTM rules. You can use the midi to playback your own samples through structure free or trigger BFD and Addictive drums.
Drum Replacement in PT? | jimbojimbo | Pro Tools 10 | 20 | 03-07-2012 03:00 PM |
Can't Auth plugs after Apple Mobo replacement? | jpoprock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-03-2008 10:56 AM |
Drum Replacement | vocalize | Pro Tools TDM Systems (Mac) | 9 | 09-20-2005 12:19 AM |
Drum Replacement | ivet | Tips & Tricks | 5 | 04-30-2001 11:48 AM |
Drum Replacement | ivet | General Discussion | 0 | 04-26-2001 09:25 AM |
