Old 11-13-2017, 05:41 PM
LightWing's Avatar
LightWing LightWing is offline
Default Re: Pro Tools AAX Plug-In Latency Chart
How is the latency being measured?
Patrick
www.LightWingStudios.com
Musical Instrument Protection Accessories...Made In America.
Dell Precision T7910, Dual Processors (total 20 Cores), 128GB RAM, 4 @ 2TB SSDs, 1 @ 4TB HDs, Nvidia 2GB Dual Monitor Card, Dual LG 48" TVs used as Monitors, Arturia 88 Midi Controller, Black Lion USB Audio Interface, Mackie HR-828 Monitors, Katana Head, Fishman Triple Play, Win 10 Pro, PT 2023.3 Studio, only the Plugins I NEED, WAY TOO MANY Guitars...and an AMAZING wife!
AxeShield HD, AmpShield HD, KeyShield HD, AxeSak, AxeGlove, AxeCap & PedalShield
Old 11-13-2017, 05:51 PM
So just confirming are all these the numbers reported by Pro Tools delay compensation or manually verified/tested?
Old 11-13-2017, 05:57 PM
Tweakhead Tweakhead is offline
1. Delay Compensation must be enabled in your Playback Engine.
2. View the Delay Compensation section in View menu > Mix Window Views > Delay Compensation (checked)
3. Insert a plug-in.
4. The 1st item (nearest the fader) in the Delay Compensation box is the value reported.
Old 11-13-2017, 05:59 PM
Well I would have thought that the number reported by Pro Tools would be correct.
I am assuming that you know about some cases where this is not true.
Would you like me to add another column for that manual check Darryl?
Old 11-13-2017, 06:07 PM
No, I just wanted to understand what is being reported. It would be good to add a note in the spreadsheet that the data is the reported latency...
Sure there are cases where plugins get delay comp wrong, I can't think of the exact cases now.
This will be helpful for folks. Thanks.
  #16
Old 11-13-2017, 06:12 PM
OK. Done.
  #17
Old 11-13-2017, 06:33 PM
Just a quick tip for anyone contributing to the spreadsheet . . .
If you've run out of space to add another plug-in in a certain manufacturer's section - just select the row at the far left (click on the number) and from the "Insert" menu choose either "row above" or "row below" . . . whatever makes sense to you.
You can undo/redo mistakes with the two little curved arrows under the "Edit" menu.
  #18
Old 11-29-2017, 10:34 AM
PatrickCusack PatrickCusack is offline
Thanks for the quick response. What is the ETA on 3.8? Is that compatible with WSControll app 3.6.1 and above?
  #19
Old 12-14-2017, 11:06 AM
ProsTools ProsTools is offline
Waves has a webpage showing their plugin latency.
https://www.waves.com/support/tech-specs/plugin-latency
  #20
Old 12-21-2017, 04:38 AM
huzzam huzzam is offline
Just added some entries, mostly for McDSP & SoundToys, but also Valhalla, Massey, plus Waves SSL Bus Comp. (all 48kHz/Native)
Many of the ones I posted were "0", which i figure is useful information. (I mention it because previously there were almost no zeroes in the spreadsheet.)
~peter in athens
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest
* Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1
* PT 23.6 + Ableton Suite 11.3
* Soundtoys + Valhalla + Fabfilter + Spitfire
* RME Fireface UCX II ~ Arturia Keylab Essential 49
* various clarinets, trumpets, flutes, plucky stringy thingies
Display problem with AAX Plug-ins Chart Darryl Ramm AAX Plug-ins 8 07-12-2012 03:50 PM
Digi 003 Rack Latency chart needed Kempo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 10-16-2010 05:13 PM
RAM LIMITS/ Plug-In Chart?? Troy Tracks Studio Pro Tools M-Powered (Win) 4 05-10-2010 09:59 PM
Is there a PT MIX/24 OS 9 Plug-in compatibility chart? storypod Pro Tools TDM Systems (Mac) 0 02-23-2008 08:54 AM
Is there a delay/latency reference chart for LE ? MKZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-09-2007 06:49 AM
