Old 09-23-2017, 02:52 PM
Default Re: Another iLok victim.
Originally Posted by James Richmond View Post
I leave mine plugged into my NAS at the studio using some software called Virtual Here when I am doing location recording.
Provided I have an internet connect I am fine.
Please share this in more detail as it seems like a great solution
Old 09-23-2017, 02:57 PM
http://www.pro-tools-expert.com/home...and-waves-keys
Old 09-23-2017, 03:40 PM
Originally Posted by TimothyJohn View Post
Got a case #. That's it.
If in fact you have ZDT/TLC, then by now you should have temporary licenses - if not, then you may not have filled out the correct forms on the site.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 09-23-2017, 04:36 PM
TimothyJohn TimothyJohn is offline
Originally Posted by Darryl Ramm View Post
But what *exactly* did you do? Did you start the RMA process? Not a general support case.
Meant to thank you all. Once I started the RMA, I was good. Temporary Licenses provided. Process of replacement underway.
Old 09-23-2017, 04:52 PM
Hmmm, that's a tough read for someone as "computer-challenged" as me, but I will try to dig into it. I looked at youtube, hoping for some tutorial help but came up short. Anyone here able to do a video?
  #16
Old 09-23-2017, 06:44 PM
What part is the issue? If working outside your LAN you need a VPN to get into your network. If you don't want to look into that level of stuff yourself you should be able to find a network/IT consultant to help with that. You want a carefully set up firewall and systems, ideally I'd like to see a dedicated iLok server system in a DMZ. It's likely worth getting help in an not accidentally leaving security holes in your network.
  #17
Old 09-23-2017, 07:41 PM
syMPh syMPh is offline
Sometimes the fault is just the contacts on the usb terminals are worn to the point they won't connect properly anymore. Insert the ilk fully. then give it a slight nudge one way or another in a direction which makes the terminals of the usb make harder contact.... gently... you may find that it stays lit while a little pressure is applied and once you get that reliable enough then you could carefully load ilk license manager with another ilok plugged in and start transferring licenses... I wouldn't do the whole lot just a couple at a time. ii did this with a ilok that was on it's way out... good luck !
System Details
  #18
Old 09-24-2017, 01:41 PM
That's excellent advice Thanks
  #19
Old 09-29-2017, 12:45 AM
Mista Min Mista Min is offline
Dude!!!! This is amazing stuff!!! OMG! Game changing stuff man! Thank you for sharing this!!!
Next Victim - Artist surfaces do not work with PT11 but work fine with PT10 jimmyjayp Artist Series 10 12-29-2014 03:38 PM
Transfer iLok auth. from old iLok to new 003 factory iLok? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-20-2007 07:05 PM
help for a poor crash victim! (plus a/d conversion advice) Stevedrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-01-2007 01:50 PM
Another Power Harness Victim....U Could Be Next Third Eye Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 06-14-2005 06:48 PM
another victim of the switching optical format and/or spdif mirroring bug kmshroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-01-2003 02:35 PM
