No Signal on Master Fader 002 during Low Latency?
Weird issue.... 002 Rack PT LE 6.9.2.... I get no signal only to the Master Fader when in Low Latency mode... I see signal on the track that I am recording to, but that signal does not get to the Master Fader... when I take the 002 out of Low Latency mode the signal gets to the Master Fader? I am trying to record 2 tracks at 96kHz through an external pre... I have always seen the input signal, whether in Low Latency or whether in 44.1, 48 or 96.... I have never seen signal on the Master Fader while in Low Latency during any of these sample rate sessions... My Master Fader outputs are assigned to Outputs 1 and 2 like they should be...... what gives?
Re: No Signal on Master Fader 002 during Low Latency?
Also, I have signal to the Master Fader only when my track output is anything but 1 and 2.... for instance... if I have a track in record and the output is 3-4 and the Master Fader output is 1-2... I don't see it, obviously, if I switch my Master Fader output to 3-4 I see signal but still hear nothing.... does all this have to do with the DigiCore Manager?
Do you have any plug-ins on the master fader?
In Low Latency Mode the mix is done on DSP chips in the 002 -- so you won't see metering on the Master Fader.
From your Getting Started Guide: When Low Latency Monitoring is enabled, any plug-ins and sends assigned to record-enabled tracks (routed to Outputs 12) are automatically bypassed, and must remain bypassed. Also, these tracks will not register on meters for Master Faders. Rail
Im getting a much stronger signal on my left side of Master Fader while Im in record | shamanrock | Windows | 0 | 04-12-2012 10:56 PM |
Basic Gain Structure Fader/Master Fader Question | acmost | Pro Tools TDM Systems (Mac) | 1 | 05-16-2011 05:36 AM |
Master Fader 6.7 Master Fader issues | Bogner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-19-2005 07:42 AM |
Master inserts are post-fader? Was: L1+ on Master = clipping | s2n | Pro Tools TDM Systems (Mac) | 10 | 11-20-2001 07:41 AM |
Signal Path Question/Master Fader | dkrausz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-20-2001 04:57 AM |
