Old 09-02-2019, 06:17 PM
ZacMenton ZacMenton is offline
Default Re: Delaying the Last Word Without Mapping Every Single Word on Automation
Originally Posted by Benoni View Post
What about using AudioSuite and rendering the delay on just the words you want?
Other than that, a ducking delay as mentioned would work great for this. The bx_delay 2500 has ducking built-in.
Sounds like what I need. Thank you!
Old 09-02-2019, 06:18 PM
Originally Posted by Led View Post
Create an audio track directly below the vocal, put a delay on the insert set to 100% wet.
Go through the vocal and select/highlight each word you want the delay on, hit control + c to copy, hit : to move down to the track below then ctrl+v to paste. It's also good to eq the delay track a bit after the delay insert to put it in it's own place frequency wise. You can set the delay tempo to slave to BPM, but it's often good work out the timings for say 8th or quarter notes and set it just off that, gives it a bit of a groove, go for the closest prime number..
Very good advice. Although I plan to use a dynamic delay to 'duck' both the vocal AND the time it'll take me to automate the whole line, your advice is still helpful as I forget ab the uniqueness of each part despite it having to fit in the mix altogether. Again, thanks!
What in the word is going on ????????????????????? shaun1234 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-22-2007 08:37 AM
The L word.. studiostefan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-24-2006 04:46 AM
Echo a single a word fmcarrio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-21-2006 04:07 PM
Word 1x vs. Word 256x bennychico11 Tips & Tricks 2 12-29-2005 07:26 AM
Any word on PT LE 5.1? yavuzj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-08-2001 06:54 AM
