Old 07-16-2013, 03:45 PM
robertg robertg is offline
Default Logic X and Eucon?
Is there any Eucon support for Logic X yet?
Old 07-16-2013, 04:27 PM
denka's Avatar
denka denka is offline
Default Re: Logic X and Eucon?
Control & Mix work nice, I can't get Transport to work...
AVID HD Native PCIe + HD OMNI; Digidesign 192 I/O (2x) & 96 I/O; Icon QCON Pro & QCON EX; Softube Console 1; NI Kontrol 25; Arturia SparkLE; UAD-2 Satellite DUO; UAD-2 PCIe DUO; Tascam DA-3000; TK Audio BC1-S; Warm Audio WA76; SSL XLogic Alpha Channel (x2); SSL X-PATCH; Lindell Audio 6X-500, 7X-500 & PEX-500 (all x2), lots of TCE & Lexicon reverbs; VintageMaker LittleOne 16/2 Summing Mixer; MUTEC MC3+ SmartClock; Mac Pro (2009) 8 Core 2.26; 24 Gb RAM; Pro Tools HD 12.8
Old 07-16-2013, 05:50 PM
It works but there's a bug, the name of the plug-ins don't show up over the mix/control when you insert them via the surface, although they are selectable and editable.
Old 07-16-2013, 10:26 PM
Yore Yore is offline
When I opened Logic Pro X, my EuCon Mc Control was recognized but it didn't read the settings so none of my programming appeared (all the soft buttons).
How do I load the Logic Pro 9 settings to my Logic Pro X on EuCon ?
Thanks
Old 07-16-2013, 11:21 PM
And answering my own question: I just copied the Logic Pro.xml file and named it Logic Pro X.xml file and it's all right now.
I'm still using EuCon 2.6.2 as it seems to be working fine.
Old 07-18-2013, 03:28 PM
DanielEUCON's Avatar
DanielEUCON DanielEUCON is offline
This! Apple seems to have changed the application name which is used to load the soft keys (xml file).
Since Apple does not provide their own soft keys like Pro Tools, and Steinbergs apps (as well as several others) the new Logic Pro X application will not have a matching set of soft keys...
the workaround you mentioned is correct.
Old 07-20-2013, 02:01 AM
WITELITE WITELITE is offline
Where is the XML file to rename. Where is it stored???
Old 07-20-2013, 06:36 AM
Hauraki2003 Hauraki2003 is offline
Witelite, on my Mac: Library\Application Support\Euphonix\UserSets\...
Worked fine for me.
Old 07-21-2013, 07:15 AM
Xill Xill is offline
Location: Planet Earth, Milky Way Galaxy, Observable Universe
When will things be patched up for Logic X?
Old 07-21-2013, 10:14 AM
Chingy Chingy is offline
Experiencing something really weird with the Artist Mix and Logic X - the select buttons open up EuControl Settings instead of selecting the track. And the Record Arm buttons cycle through the automation modes instead of toggling record enable on the track.
Anybody else experiencing this? This is with Eucon 2.71.
Edit: it seems to work sometimes, but then something happens and it displays the behavior above.
ML 10.8.4 + Eucon + Logic 9.1.7 = Crash rogue303 Artist Series 12 07-25-2014 01:51 PM
your experience with logic X and Eucon 3.1 b.riesel Artist Series 6 07-25-2014 07:55 AM
New Eucon 3.1/Logic X Bug sonofmack Artist Series 0 01-23-2014 07:09 PM
[Logic Pro 9 & Artist Mix] Incompatible EuCon version at initialization w00fa Artist Series 26 04-05-2013 07:17 AM
Logic Unexpectedly Quits when Loading EUCON Support holymusicproductions Artist Series 0 03-19-2013 11:17 PM
