Old 04-18-2004, 01:53 PM
tooloud4u tooloud4u is offline
Default Pro Tools LE does not open when clicked
I have an interesting problem that I have also seen listed a few months back, but no one had a solution.
So here it is again....
Pro Tools 6.1.1 is installed. All updates have been applied, but even though Windows XP loads the hardware for the MBox, Pro Tools LE immediately crashes and asks you to cancel or debug. Debug doesn't work, but you are able to get some info on the crash. Below is what Windows immediately says about the error:
AppName: protoolsle.exe AppVer: 6.1.1.53 ModName: unknown
ModVer: 0.0.0.0 Offset: 020eeab2
I can also get a lot more error data from the logs, but nothing says why it crashed.
I have tried un-installing quicktime and installing LE, deleted all known occurances from the machine for Digidesign (registry, Program files, etc.) and still no luck. I have tried both the wavedriver and the ASIO drivers, but no luck.
This system use to work for about 6 months, but the OS crapped out and I had to re-install it. Now Pro Tools doesn't work at all and I have an expensive system sitting here gathering dust.
Anybody got any ideas?
Thanks,
Old 04-18-2004, 02:42 PM
Keith Owens Keith Owens is offline
Default Re: Pro Tools LE does not open when clicked
Please list your entire PC setup.
List all hardware, name brand, how much of whatever , and versions of whatever;
version of windows including SP
motherboard make and model
type of memory
type of PC
type of harddrives
etc. , etc.
soon to be back at it again...
Old 04-18-2004, 04:14 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
When you reinstalled XP did you also reinstall SP1?
Also try opening PT from its directory instead of from a shortcut.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 04-19-2004, 05:46 AM
Soyo Athlon Motherboard
Windows XP Professional
2.0gHz Athlon
1 gig ram
180 gig hardrives
USB 2.0 or 1.1. ports
Service Pack 1 is installed and windows is up to date.
Pro Tools is the only piece of software that does not work on the computer.
Thanks
Clicked Save. Deleted my session. Help! flowetic Pro Tools 10 2 10-14-2013 05:30 AM
Pro Tools mutes playback when edit window is clicked Please help Yaron Pro Tools M-Powered (Win) 4 03-18-2009 07:26 AM
100% CPU when control clicked in mix window kade Pro Tools M-Powered (Win) 0 09-27-2006 12:11 PM
Plugins not workin until clicked Robby Hamilton Pro Tools TDM Systems (Mac) 1 05-01-2003 11:21 AM
clicked on the digi ? for midi but it wont open surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-30-2002 11:31 AM
