Please HELP!! Save error messages
I am getting various different save errors including Can't save while translating tracks or can't locate a certain path, etc.. you name the error and I have likely had it. It happens after I have been working with the session for an extended period of time. I thought the sessions became corrupted somehow. so, I saved a template of it and then rebuilt the session from scratch. Worked great with frequent saving by me until I finished and bounced my mix. then it would not save, or let me save a copy. then gave me a bunch of C++ run-time errors and crashed. Whether I have bounced to 2 track or not makes no difference in the frequency or time of error
This is very frustrating and I've been fighting it for a week to no avail. updated, reinstalled, etc, etc... No info that I have found seems to solve the issue. I've shut off auto save function which was also giving me errors. I found that suggested on this forum, still nothing. Please help!!! I'm desperate. Thanks...... |
Re: Please HELP!! Save error messages
Hi, It's hard to say without more info about your system and which version of Pro Tools you're running. Have you tried a clean reinstall of Pro Tools? Have you gone through all the Optimizations for your O/S? Make sure you go through everything here:
Help us Help You - READ THIS Before Posting! And post a SANDRA report. My first thoughts are a corrupted Pro Tools install, or something wrong in Windows, or possibly some bad RAM. Chris
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Thanks!
I am running Pro Tools 10.3.5 on Windows 7. This is a clean install of the updated software. I have performed all of the optimizations and have ran a SANDRA report which appears below. The first error I get is: "cannot save "Session_name" because translating tracks Then: Could not save "session" because access violation occurred. unable to read location: 0x250048FE. Then I get" Can't save due to fatal error Then it says I need to allocate more memory and then Pro Tools shuts down. I"ve allocated all the memory I can but still nothing. I have also disabled auto-save function. Please see report below...and Thanks! SiSoftware Sandra ID Host Name : ProToolsPC-PC Workgroup : WORKGROUP Computer Model : GigaByte Serial Number : To be fille*********** Chassis : GigaByte Desktop Mainboard : GigaByte X79-UD3 Serial Number : To be fille*********** BIOS : AMI (OEM) F11 07/05/2012 Total Memory : 16GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (4C 8T 3.7GHz, 3.7GHz IMC, 4x 256kB L2, 10MB L3) Socket/Slot : FC LGA2011 Chipset Memory Controller : Gigabyte Core DMI2 (Sandy Bridge-E) 100MHz Memory Controller : Gigabyte Core (Sandy Bridge-E) Integrated Memory Controller Registers 100MHz, 4x 4GB DIMM DDR3 1.6GHz 256-bit Memory Module(s) Memory Module : F3-12800CL9-4 4GB DIMM DDR3 PC3-12800U DDR3-1600 Memory Module : F3-12800CL9-4 4GB DIMM DDR3 PC3-12800U DDR3-1600 Memory Module : F3-12800CL9-4 4GB DIMM DDR3 PC3-12800U DDR3-1600 Memory Module : F3-12800CL9-4 4GB DIMM DDR3 PC3-12800U DDR3-1600 Video System Monitor/Panel : Samsung SAMSUNG (1600x1200, 40.2") Monitor/Panel : Samsung SAMSUNG (1600x1200, 31.5") Video Adapter : NVIDIA GeForce GT 520 (1CU 48SP SM5.0 1.66GHz, 64kB L2, 2GB 1GHz 64-bit, PCIe 2.00 x16) Video Adapter : NVIDIA GeForce GT 520 (1CU 48SP SM5.0 1.66GHz, 64kB L2, 2GB 1GHz 64-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce GT 520 (48SP 1C 1.66GHz, 64kB L2, 2GB 1GHz 64-bit) Compute Shader Processor : NVIDIA GeForce GT 520 (48SP 1C 1.66GHz, 64kB L2, 2GB 1GHz 64-bit) CUDA GP Processor : NVIDIA GeForce GT 520 (48SP 1C 1.66GHz, 64kB L2, 2GB 1GHz 64-bit) Storage Devices WDC WD5003AZEX-00K1GA0 (500.1GB, SATA600, 3.5", 7200rpm) : 466GB (C:) WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (D:) HL-DT-STDVDRAM GH24NS90 (SATA, DVD+-RW, CD-RW) : N/A (E:) Logical Storage Devices System Reserved : 100MB (NTFS) Audio Drive (D:) : 932GB (NTFS) @ WDC WD1002FAEX-00Z3A0 (1TB, SATA600, 3.5", 7200rpm) System (C:) : 466GB (NTFS) @ WDC WD5003AZEX-00K1GA0 (500.1GB, SATA600, 3.5", 7200rpm) Optical Drive (E:) : N/A @ HL-DT-STDVDRAM GH24NS90 (SATA, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : Gigabyte Patsburg LPC Controller LPC Legacy Controller 1 : T2 87-28 Audio Device : Gigabyte Patsburg High Definition Audio Controller Audio Device : EVGA HDMI Audio stub Audio Codec : nVidia 001C Audio Codec : 1 0001 Serial Port(s) : 1 Disk Controller : Gigabyte Patsburg 6 Port SATA AHCI Controller Disk Controller : Gigabyte 91xx SATA 6G Controller Disk Controller : Gigabyte 91xx SATA 6G Controller Disk Controller : Gigabyte 91xx SATA 6G Controller USB Controller 1 : Gigabyte Patsburg USB2 Enhanced Host Controller #2 USB Controller 2 : Gigabyte Patsburg USB2 Enhanced Host Controller #1 USB Controller 3 : Gigabyte FL1009 USB 3.0 Host Controller USB Controller 4 : Gigabyte FL1009 USB 3.0 Host Controller FireWire/1394 Controller 1 : 13330 XIO2213A PCI Express to 1394b OHCI with 3-Port PHY SMBus/i2c Controller 1 : Intel ICH SMBus SMBus/i2c Controller 2 : Intel SNB-E XMB Ch 0 SMBus SMBus/i2c Controller 3 : Intel SNB-E XMB Ch 1 SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Intel(R) 82579V Gigabit Network Connection (Ethernet) Wireless Adapter : Linksys WUSB600N Wireless-N USB Network Adapter with Dual-Band ver. 2 #2 (802.11g (ERP), AES-CCMP, 144Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.8 Last edited by thruhiker; 04-28-2013 at 07:16 PM. |
I am not trying to be snarky, but the well intended link above:
http://duc.avid.com/showthread.php?t=300050 is full of dead links.
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002) |
The only dead link I can see is the "Search the Knowledgebase" link, and that link is accessible from the forum header!
Daniel Asus P6X58D-E, Intel i7 930, 12 Gb Corsair XMS3 DDR3 2 WD Black Cavier 640 Gb SATA 3Gb/s 32MB Cache Windows 10 Pro |
Yes no problem finding the links I needed despite the dead one.
Have you installed any third party plugins?
Tried starting PT with plugins disabled?
"In theory there is no difference between theory and practice. In practice there is." - Yogi Berra |
I do have 3rd party plugins. Slate digital stuff. as well as P&M plugins. also amplitube 3 but not using it in the sessions I'm haveing issues with.
I'll try all these suggestions tonight. Thanks!! |
(-50) ERROR on Save / Auto Save | oldrake | macOS | 1 | 10-14-2013 03:30 PM |
Many different error messages, Pro Tools aborting or unable to click messages off | riffmachine | Pro Tools M-Powered (Win) | 5 | 10-05-2010 04:15 AM |
Error Messages | Guitarboy Rocks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-12-2007 12:03 AM |
Mac error messages..help please? | james3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-22-2005 10:08 AM |
error messages | Vinnie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-09-2000 01:23 AM |
