Old 09-20-2019, 02:14 PM
agent525 agent525 is offline
Default Pro Tools Ultimate Will Not Open
I can not get the program to open, I get this message every time I try to open it.
Could not complete your request because Assertion in "E:\ Code\ 238951\ ProTools\ AAE\ Source\ AAX\ CFicAAXWidget.cpp", line 994.
(Use the Copy button to copy this message to the clipboard.).
Can anyone help me on this?
Old 09-20-2019, 02:26 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Pro Tools Ultimate Will Not Open
Welcome to the community.
This is typically a driver/engine related error. Please try launching PT then immediately hold the N key until the Playback Window opens. If this doesn't help please reply with complete system details.
linkedin
Old 09-20-2019, 02:37 PM
It almost opened up then close out with no error.
OS Name Microsoft Windows 10 Pro
Version 10.0.18362 Build 18362
OS Manufacturer Microsoft Corporation
System Manufacturer Dell Inc.
System Model XPS 15 7590
System Type x64-based PC
System SKU 0905
Processor Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz, 2400 Mhz, 8 Core(s), 16 Logical Processor(s)
BIOS Version/Date Dell Inc. 1.2.3, 7/23/2019
SMBIOS Version 3.2
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Dell Inc.
BaseBoard Product 0T8KGX
BaseBoard Version A00
Platform Role Mobile
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Hardware Abstraction Layer Version = "10.0.18362.356"
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.7 GB
Available Physical Memory 21.2 GB
Total Virtual Memory 36.5 GB
Available Virtual Memory 23.4 GB
Page File Space 4.75 GB
Page File C:\pagefile.sys
Kernel DMA Protection On
Virtualization-based security Not enabled
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualization Enabled in Firmware Yes
Hyper-V - Data Execution Protection Yes
Pro Tools Ultimate 2019.6
Old 09-20-2019, 08:17 PM
jeffro's Avatar
What audio hardware (and driver version) are you using?
linkedin
Old 09-21-2019, 07:56 AM
Audio built in Dell XPS 15 laptop
Realtek Audio
Driver Realtek Semiconductor Corp
Driver Version 6.0.1.8652
Old 09-21-2019, 08:57 AM
Realtek Audio
I am pretty sure that is a non-ASIO device—Did you install ASIO4ALL and configure it to use/wrap that device? What exact option are you seeing in the Playback Engine dialog. Screenshots of the playback engine dialog and the ASIO4ALL control panel may help if you are stuck.
You will be better off getting a dedicated interface with an interface vendor supplied ASIO driver. If you describe what you are doing, and price range, folks here can recommend interfaces to you.
Old 09-21-2019, 08:59 AM
Southsidemusic's Avatar
If you dont have an interface for audio which you really should look into try downloading Asio4all which is a free virtual asio driver ”band-aid” and not seen as an ”instead” of a audio interface but a temp fix.
It is a widespread used software so no crap malware.
www.asio4all.com
Edit: LOL Great Minds Think Alike!!
Saw you posted after I published my post so even better for the OP as we said the same thing in slightly different way.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Pro Tools Standard->Pro Tools Ultimate Cross-grade clarifications. Akiz Licensing & Accounts 8 08-30-2019 10:34 AM
Latency with Pro Tools Ultimate vs. regular Pro tools 2018 DualCoreX2 macOS 5 04-25-2018 08:17 AM
Pro Tools Ultimate YYR123 General Discussion 13 04-08-2018 10:24 PM
Vista Ultimate 64 (the ultimate dissapointment) Filmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2009 04:44 AM
