Old 12-30-2002, 07:05 PM
hitwriter hitwriter is offline
Default synced with pro tools- see signal, but can\'t hear signal- HELP!!!!
I have synced to pro tools, and have made the mpc the master, oo1 slave. I also have the audio of the mpc going to tracks 3/4 of 001. When record enabled I see the signal on tracks 3and 4 but hear nothing, as well as no audio waveform shows on the screen, but I see the SIGNAL! What is the problem?
Old 12-30-2002, 10:08 PM
Bastiaan Bastiaan is offline
Default Re: synced with pro tools- see signal, but can\'t hear signal- HELP!!!!
maybe you actually have to start recording
1. set up a channel to record to (audio-channel, not aux-channel...)
2. route an input to that channel
3. record enable the channel (little "rec" rectange above the fader.)
4. hit the record-button in the transport-section
5. hit the play-button in the transport-section
(or skip step 4+5 and press 3 on the numerical keyboard with num-lock switched on...)
now you are recording....
To listen to what you do, you ether have to connect a headphone to the digi001, or connect your amplifier or powered monitors to the "monitor out" on the back of the break-out box. The monitor-button on the front of the box should be depressed!
All this is perfectly written down in the getting started guide...
What's that?
- That's the machine that goes "pling".
Bastiaan
No audio signal or midi signal after pro tools 8.04 upgrade allgenres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-01-2010 08:58 AM
Pro Tools shows signal but I dont hear anything??? drumzalicious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-22-2010 11:30 AM
I see no signal but I hear a sound. HB1978 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-29-2010 07:07 AM
I can see the signal but I can't hear my keyboard? producermandan66 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-01-2007 09:51 AM
Can't hear MIDI signal firstbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-18-2005 07:31 PM
