Old 05-12-2001, 06:27 PM
Derek S Derek S is offline
Default Syncronizing Two Computers Running PT
I have a G4 with a Digi001 and PTLE 5.0.1. I have an Opcode Studio 128X I used to sequence when I used my PC for audio. I'm having trouble getting rid of it, so I installed PT Free on my old PC. I'd like to do MIDI sequencing on the PC and synchronize it to the G4. I figure this serial port interface will be better and less expensive than any G4-sequencing solution.
I read the PT Reference Guide, but that was of little help to me. I'm not sure which options I have available to me. Most PT-specific info was for using a Mac with OMS and a serial MIDI interface.
The question:
Which computer should be the master, which the slave? I'd like the G4 to be the master, but is it even possible to send sync signals from the Digi001? More importantly, is this the best solution?
For whichever direction you recommend, how do I go about setting it up? I'm not even sure which sync method to use.
I'm assuming that I'd need to hook the two computers by two MIDI cables, correct? Should I be using MMC?
i7 computers with problems running protools 8 on windows 7 bmenchen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-07-2010 05:02 PM
Running the same copy of PT on two computers rabssi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-02-2009 11:59 AM
Syncronizing Audio Files with PT 7.4 deepbleu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-22-2008 05:40 PM
Syncronizing Roland Just Starting 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-22-2003 10:02 AM
protools in running in 2 computers del cosmos Pro Tools TDM Systems (Mac) 2 03-18-2001 07:17 AM
