Old 07-06-2005, 02:32 PM
elv1s1sal1ve elv1s1sal1ve is offline
Default aux track signal but no midi signal?
Why can I get midi instrument signal through the aux track but none from the midi track that's being sent to the aux? The obvious issue that this presents, among others, is that I can hear the instrument but can't record it. Any ideas?
Gateway 7510GX, AMD Athlon 64 3700+ 2.39 GHz, Windows XP Pro, PTLE 7.3.1.123, MBox, 1 GB RAM, external Seagate 150 GB HD
Old 07-06-2005, 02:38 PM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Re: aux track signal but no midi signal?
rec enable the midi track
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 07-06-2005, 02:42 PM
did that. I've done this before several times, and as far as I can tell, I'm not doing anything different than I always do. I'm totally perplexed.
Old 07-06-2005, 03:05 PM
Cliffy_Boy's Avatar
Make sure midi thru is turned on in the midi menu. Make sure you've selected the corrected midi outputs. Check that the midi cables are in to out and out to in.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 07-06-2005, 07:00 PM
Follow Cliffy Boy's info and if it still doesn't work, check that your midi track is set to "ALL" on the input.
Old 07-06-2005, 07:18 PM
will the moor will the moor is offline
Follow CliffyBoy and Albee's info and if it still doesn't work, pray to the gods of outdated, limiting, non-musical serial protocols and see if that helps.
Will
http://soundofthatday.com
Digi 003/ LE 8.3 PROBLEM...NO MIDI SIGNAL FROM INTERFACE TO TRACK... josh2010 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-27-2012 08:48 AM
Instrument Track Inserts B+ no midi signal rmoat Windows 3 01-15-2011 04:49 PM
No audio signal or midi signal after pro tools 8.04 upgrade allgenres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-01-2010 08:58 AM
No MIDI signal to Instrument Track suddenly. Help! SoundtrackArcade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-03-2006 10:57 AM
No Midi signal, no audio signal, buzzing monitors! 1tonstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-26-2004 07:01 AM
