Old 06-01-2020, 04:05 AM
LDS LDS is offline
Default Strange Avid Omni Channel Order Issues
I've really been struggling to find some kind of consistency with channel orders with my Avid Omni setup. Today I recalibrated things, and notice some strangeness with the monitoring channel order, meters and audio midi setup.
- My Avid Omni is configured for SMPTE 5.1 - L, R, C, LFE, LS, RS.
- My monitors are patched to match - L, R, C, LFE, LS, RS, 1 through 6.
- Playing test tone through each channel in Pro Tools confirms the correct configuration.
- The output meters on the Omni, however, always indicate a 5.1 FILM setup, L, C, R, LS, RS, LFE. I've tried adjusting the meter output I/O configuration in Pro Tools, but it has no effect. The metering always remains the same FILM order.
- Setting up the channel order within the "configure speakers" menu of Audio Midi Setup in OSX also doesn't match. To match the SMPTE configuration of my monitor tab setup for the Omni, and the physical wiring of my speakers it should look like the default:
L = 1
R = 2
C = 3
LFE = 4
LS = 5
RS = 6
But to get the test tones within the configure speakers panel to match the appropriate speakers, I need to set it to the FILM standard.
L = 1
R = 3
C = 2
LFE = 6
LS = 4
RS = 5
That doesn't make a lot of sense to me at all, given that my left and right speaker never actually move from physical outputs 1&2. Yet on the meters, it shows as output 1&3. It is really messing with my head.
Can anyone else with an Omni and a 5.1 setup confirm that they are seeing similar behaviour? It seems like the output meters and the core audio implementation for the Omni are defaulting to FILM, rather than following the monitoring setup channel order, or defaulting to the standard SMPTE channel order that Apple seem to use within their 'configure speakers' panel. iTunes uses output 1&2 for stereo, just like the 'configure speakers' default panel would suggest. Changing the channel order in that panel has zero effect on what speakers itunes is playing from.
Running 2020.5 here - and I'm sure the meter weirdness is a new thing.
littledevilstudios.com.au
Pro Tools Ultimate 2020.5. OSX 10.14.6. HDX1. Avid Omni. Mac Pro 2013. 10 Core 3.0gHz. 64Gb. 4x mSata SSD Drives + 4x HDD. AJA XT IO. Sync HD. Dobly Production Suite 3.4.
Old 06-01-2020, 07:41 AM
Tim R. Tim R. is offline
Default Re: Strange Avid Omni Channel Order Issues
I can confirm this. I have puzzled over this since I did my 5.1 setup (right when the OMNI came out). I've spent entirely too much time trying to figure it out and have just resolved to accept that the hardware meters are wrong.
Tim Reisig
System 1: Pro Tools Ultimate 2020.5, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 20.5, Rosetta 800 w/XHD card
Mac OS 10.14.6, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 2019.12 (no Hardware), Mac OS 10.14.6, MBP (Retina 13in, Early 2015, 3.1Ghz i7, 16Gig RAM)
Sync HD , Omni, Logic Pro X and Avid Audio Server issues... PT user macOS 0 03-07-2018 01:33 PM
Omni channel/meter order confusion dalonso66 Pro Tools HDX & HD Native Systems (Mac) 8 03-31-2016 12:36 PM
API Channel Strip to AVID HD Omni jgiannis Pro Tools 10 11 02-13-2016 01:01 PM
LOGIC PRO X and Avid Omni issues PT user Pro Tools HDX & HD Native Systems (Mac) 5 12-29-2015 07:30 PM
Strange CoreAudio issue - right channel information getting into left channel -JK- Pro Tools 9 5 01-10-2011 08:42 AM
