Old 12-07-2010, 01:04 PM
reichman's Avatar
reichman reichman is offline
Default BUG: Nudge Underlying Audio/Sync Point
Maybe this has been covered before, but when you use ctrl +/- to nudge the underlying audio (while leaving the start and end the same), any sync point in the region stays in its absolute position, and doesn't move with the audio (!).
Defeats the point of using sync points...
And, yes, for the record, this is my biggest problem with PT9
Old 12-07-2010, 01:52 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Default Re: BUG: Nudge Underlying Audio/Sync Point
I don't think it ever did.
Vedat
WaveRider + Defaulter now on SALE
QuietArt.co.nz
Catchin' SYNC app
Old 12-07-2010, 03:03 PM
reichman's Avatar
Right. I think sync points might have always behaved this way. But it still doesn't make sense.
Old 12-08-2010, 12:42 AM
Vovique Vovique is offline
Assure you, this feature works just as intended. It just saves you a couple of mouse drags: instead of having to first move the sync point and then drag the region to align the sync point to the corresponding event, you just nudge the underlying audio using this shortcut.
Old 12-08-2010, 05:27 AM
reichman's Avatar
Vovique, I'm not sure I follow. The nudge function works fine, the issue is that if you have an existing sync point, it doesn't move with the audio. That's the problem.
This bug is especially problematic in music editing.
Old 12-08-2010, 07:33 AM
minister's Avatar
minister minister is offline
It is a region sync point. As such it is tied to the region, not to the sample. You want a sample level sync point, which PT does not do at this time.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
HTML code is On
Nudge and sync point henpage Pro Tools 10 0 08-07-2012 10:26 AM
Sync point doesn't move with ctl-nudge (?!) alex weber Post - Surround - Video 1 08-14-2010 03:08 AM
Crtl-nudge and sync-point Frank Kruse Post - Surround - Video 3 04-09-2009 02:16 AM
Sync point doesn't move with ctl-nudge (?!) reichman Post - Surround - Video 0 11-24-2008 12:52 PM
Snap sync point to sync point? imi Tips & Tricks 3 05-25-2003 06:48 AM
