Problem setting up ServLT
I've just bought a ServLT and am having problems with the initial setup. It connects to my network via Ethernet1 fine, and to a local PC via Ethernet2. However, when I try to enter the network information it restarts the services and comes up with network errors. I've checked that all the relevent ports are open on my router, and there is no firewall installed. I've also checked with my ISP and they don't block any of those ports. All the ports out seem fine, but none of the ports in seem to work. I'm not sure if its actually a port problem or if the DigiDeliveryTest.cgi file is actually missing somehow. I tried using a DMZ to the Serv LT IP but even with that it gave the same errors. I can't seem to get any further, as what ever I do it will not get further than this error. I've pased the error below so any thoughts would be really appreciated as I'm not sure what to try. Thanks, Phill. Network Tests Failed. There may be a problem with your network configuration. [ OK ] IP Address 10.1.1.50 [ OK ] Gateway address 10.1.1.1 [ OK ] The DNS Servers 212.23.6.100 212.23.3.100 appear to be working satisfactorily [ OK ] Port TCP/25 OUT is open [ OK ] Port TCP/80 OUT is open [ OK ] Port TCP/443 OUT is open [ OK ] Port UDP/123 OUT is open [WARNING] Port TCP/22 IN Not Found The requested URL /cgi-bin/digiDeliveryTest.cgi was not found on this server. [WARNING] Port TCP/443 IN Not Found The requested URL /cgi-bin/digiDeliveryTest.cgi was not found on this server. [FAILED ] Port TCP/80 IN Not Found The requested URL /cgi-bin/digiDeliveryTest.cgi was not found on this server. [FAILED ] Port TCP/80 IN Not Found The requested URL /cgi-bin/digiDeliveryTest.cgi was not found on this server. [FAILED ] Port TCP/80 IN Not Found The requested URL /cgi-bin/digiDeliveryTest.cgi was not found on this server. [FAILED ] Some Tests Failed |
Re: Problem setting up ServLT
Hi Phill,
Email me your static IP and user/password for the Digidelivery (you can change it when we've got it going!). Has it got the latest software (2.2.1)? Pete |
Hi Pete,
Thanks for the offer of help with it, much appreciated! It seems to all be working now though. I sent an e-mail to Chris at Aspera and he replied saying it was an issue with the server having moved from Digidesign to Aspera and the Serv LT needed new firmware to allow it to connect. As it wouldn't get past the setup wizard I couldn't update the firmware but Bill at Aspera talked me through putting it in CS mode using a directly connected keyboard and monitor, then they were able to log into it and do the upgrades from their end. Must say I was very impressed by the immediate help from Chris and Bill at Aspera! Thanks again for the help Pete, Phill. |
Incidentally, are the ServLTs usually so noisy? This one sounds like its trying to take off some times!
Also, is the internal mail server supposed to work just set to 127.0.0.1? Sending test deliveries using the internal mail server the delivery said it had been sent fine, but I never received an e-mail with the download link. Substituting my Zen e-mail server address seemed to work fine though and I received the various e-mail notices fine. Thanks, Phill. |
Pete ps glad you got it working! |
Cheers for now, Phill. |
http://duc.digidesign.com/showthread.php?t=209317
I have exactly the same error message on a ServLT.
It has version 2.2.1 software. I have mailed support at Aspira and have had a reply asking to reboot but this made no difference. I mailed back, but have heard nothing more. |
Hi Richard,
That's a weird one as with v.2.2.1 firmware it should know the new Aspera server details (as far as I understand it). I'd recommend giving Aspera a call (I called using a ratebuster.co.uk so its only 1p/min from uk), they were really helpful on the phone when I called and sorted it all out remotely for me. You may well need a keyboard and monitor directly plugged into the ServLT though to enter commands and see what its doing, though if you have CS mode already enabled I guess that probably won't be necessary (I had to log in that way as couldn't get out of the setup wizard to enable CS mode). Good luck with it, Phill. |
Thanks for the link, but I'm not sure quite what they mean by "hostname of localhost". I tried the mail server set to 127.0.0.1 which wouldn't seem to work, but by "hostname" is that refering to the A record name of the IP address? If so I've already set that to a sub domain of my main domain, but maybe I'm missunderstanding what the "hostname of localhost" is refering to? Thanks again, Phill. |
I'm having problem setting up Pro Tools 10 | thinhtedder | Pro Tools 10 | 1 | 12-09-2013 09:23 AM |
Buffer setting problem | Djonne | Windows | 2 | 07-07-2011 12:42 AM |
Firmware Update ServLt from 2.1.1 to 2.2.1 | edemi | Aspera DigiDelivery | 2 | 05-18-2010 12:44 PM |
SOFTWARE OR SETTING PROBLEM???? | inti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-29-2004 10:09 AM |
Problem Setting Up Mbox | Pukeism | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-07-2004 04:20 PM |
