Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 05-31-2019, 09:09 AM
Tweakhead Tweakhead is offline
Default Suspend ReWire
Does anybody have any tips for a method to quickly toggle ReWire sync between two audio apps. eg Pro Tools/Ableton Live, Logic/Ableton Live, etc.
Scenario:
Working in your main audio app such as Pro Tools or Logic Pro X, and using Ableton as an additional loop processing tool running in sync via ReWire. The need is being able to just run one app or the other without having them run in sync. A quick key-command to disable/re-enable would be nice.
Anyone run into this ? or have a method of achieving suspended sync without having to go into configuration preferences to disable the entire rewire protocol ?
Old 05-31-2019, 10:28 AM
BScout BScout is offline
Default Re: Suspend ReWire
I think it would have to fall on the "follow" program.
SoundMiner Pro, for instance, has a checkbox to turn on/off Rewire sync with Pro Tools.
So I'd check with Ableton.
Old 05-31-2019, 11:02 AM
Thanks for the tip BScout. I have emailed my client with this link:
https://www.ableton.com/en/manual/li...on-and-rewire/
Old 05-31-2019, 06:22 PM
unfortunately even that "Ableton Link" doesn't work. . .
this is the key sentence:
Using Link is not possible when Live is used as a ReWire device. Link can be used, however, when Live is the ReWire host.
So, Ableton can be launched first, making it the ReWire host (master), but then launching Logic, which would usually make any other app the ReWire slave . . . doesn't work because Logic always has to be the master "host" device. I think Pro Tools is the same.
It's a shame the various manufacturers have not got together in this modern day and age to develop this excellent protocol just a little further than it currently exists. It seems to have sat without any improvements since its inception.
Suspend automation lindellsound Pro Tools 11 3 12-08-2015 04:47 PM
Use of Suspend Automation ramu745 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-15-2009 08:18 AM
7.3.1 cs 5 & group suspend button ! ? priorytools ProControl, Control|24, Command|8 2 10-16-2007 01:59 AM
Suspend Automation Playback for some but not all Don Geppert Pro Tools TDM Systems (Mac) 3 02-16-2006 04:31 PM
Suspend grid mode Audiofarm Pro Tools TDM Systems (Mac) 1 11-21-2004 01:49 AM
