Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 03-17-2019, 05:37 AM
TDub TDub is offline
Default Wilkinson Debleeder VST
Hey all,
I really want to get Wilkinson Debleeder plugin. I see it seems to say it is VST and works 32 bit.
I have FXPansion ... so I'm assuming I can use that to convert to RTAS.
But before I pay the money, I was wondering if anyone else is/has used it and it works? (not if it does a good job debleeding ... but if it will indeed convert to rtas and work in an older version of PT like mine (PT8.03)
I'm scared I will buy it and it not work, and there goes the $$
Thanks!
Tdub
TDub
Digi002 R with Command 8 - PTLE 8.03
Intel Quad Q9550
Asus P5Q Pro
Win XP
4GB
Old 03-18-2019, 08:04 AM
Default Re: Wilkinson Debleeder VST SOLVED/WORKS
Ok, well after listening to a session last night where the snare mic was picking up an incredible amount of cymbal bleed (grrrrr) .. I broke down and purchased the Debleeder plugin from the website (on for $30 USD) in hopes that it would work on my system, using FXPansion, since it is VST.
Good news: IT WORKS!! And though i only tried it briefly on that one track, from what I can see, it works WELL! Much better result than a gate and more natural.
Anyhow, in case it helps anyone else still stuck in the past with an older PT system and windows 32 ...
TDub
Intel Quad Q9550
Asus P5Q Pro
Win XP
4GB
