Old 02-16-2018, 03:44 AM
metalmick metalmick is offline
Default Assigning midi channels to tracks.
I am working in PT8 and trying to create a midi file in pro tools. I have created several midi tracks but have no idea how to assign a different midi channels to each track. I know how to route to the internal sampler but surely this is not the same thing. I expected to see a midi channel selector tab for each track.
Old 02-16-2018, 10:42 AM
Top Jimmy's Avatar
Default Re: Assigning midi channels to tracks.
The I/O assignments for MIDI tracks are in the same place where audio I/O assignments are for audio tracks, that is directly above the automation mode setting on each track in the mixer. By default, each MIDI input is set to ALL(Omni). Click on this and you can choose to narrow the input down to just a specific channel from a specific device.
The MIDI I/O assignments for Instrument tracks are found in a different place. You have to enable instrument view, View>Mix Window Views>Instruments. This will show the MIDI I/O at the very top of the instrument channel strip in the mixer. This input too is set to omni by default, but can be narrowed down to a specific device and channel.
James Cadwallader
Old 02-20-2018, 03:10 PM
Thanks for that. I have selected Midisport 1X1, midi channel 1, from the drop down list however I'm getting no sign of midi at the interface. Any ideas why that would be? The Midisport turns up in my midi devices and the output menus so why is not getting to the interface itself?
Old 02-20-2018, 03:38 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
What exactly are you trying to do?
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 02-20-2018, 03:40 PM
Top Jimmy's Avatar
I don't know why you're not getting anything. I suppose you can try swapping the in and out plugs to be sure they're plugged into the right jacks.
I once had a Midisport Uno. I got rid of it because it was problematic just like what you're experiencing. At the time, I replaced it with a Fastlane which always worked flawlessly.
James Cadwallader
Old 02-21-2018, 02:43 AM
I'm trying to get midi out of a pro tools session, through my Midisport 1X1 and then into hardware. I've routed the midi channel in and out to the 1X1 and the midi IN works perfectly but I'm getting no midi out. Not sure if its a pro tools problem or a pc problem. I will try different usb slots.
assigning different instruments to different midi channels jsbrown MIDI 1 12-14-2008 01:19 PM
Assigning Midi channels to notes William 2014 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-11-2005 03:03 PM
Assigning individual MIDI channels with Kontakt bousley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-26-2003 01:16 PM
Assigning Midi Channels skyhawk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-14-2003 09:44 PM
Assigning MIDI tracks/channels KT Digidesign Hardware & Software 1 10-17-2001 06:49 AM
